help with dreambox 800 se
  • pspmixer
    • Jun 2009
    • 750
    DM800 help with dreambox 800 se
    ive tried to flash my dm800se with openpli image from there website
    but now I get message on box screen saying Ro1 : no ca found
    I followed the tutorial on here and didn't work
    as when I tried to press flash button first time round it did nothing
    p.s I installed all drivers for sunray flash up correct to as I can connect to it on my windows 7 computer with a mini usb lead
  • pspmixer
    • Jun 2009
    • 750
    now
    I need to transfer a .xml file over too etc/tuxbox folder
    also does any one know all transponders, frequencies and symbol rates for my area as need them before can work or atleast try to get working
    ive also got to change some things on .xml file but don't understand what they mean so I copy here see if anyone knows what to do - ' edit on cable.xml the only other to change for symbol rate 6952 is fec inner 7 and modulation is 5 and for symbol rate 6887 fec inner and modulation are 3'
    ive attached file too if someone work out what to with it
    • pspmixer
      • Jun 2009
      • 750
      attached two pictures
      what do I edit for each
      • ypvs125
        • Dec 2010
        • 506
        Do a manual scan for frequency on yr cable network that is on yr cables.xml.
        eg; scan frequency 171,179,187,195,203,211,219,227,235,243,250 on symbol rate 6952 and modulation qam 256.
        • pspmixer
          • Jun 2009
          • 750
          ive just changed top to provider an virgin media came up so select that
          with those frequency's you posted do I have to scan each one
          • delboy13
            • 415
            can't you just do a scan with provider selected not used that image
            • pspmixer
              • Jun 2009
              • 750
              took box to friends house to try box out to scan and see if it work
              when scanning for channels to only reached 20% on the bar then didn't pick up and more channels after that, either tho it did go to 100% the number of channels found was 217
              weird thing was none of the channels worked that where found not even fta channels
              so im asking where do I go from here
              • pspmixer
                • Jun 2009
                • 750
                any ideas anyone
                • ypvs125
                  • Dec 2010
                  • 506
                  any ideas anyone
                  Try out with a different image and then make another full scan to see if it could pick out some other channels or if u got a friend with dreambox having all the channels, copy his settings over to yr box.
                  • pspmixer
                    • Jun 2009
                    • 750
                    I don't know any other clone images that work ones tried failed plus don't know anyone with dreambox on cable
