Frequency for Disney XD..
  • mtreams
    • Jan 2013
    • 7
    Hi Guys,
    What is the frequency for Disney XD & HD?
  • halfpain
    • Mar 2013
    From the SG Bouquet XML, the frequency for Disney XD is 394. However, when auto-scanning that frequency, I'm not getting it or any other channels that are on the 394 frequency.
    I have a FYHD HDC-800-IV so any advice on this would be much appreciated. Many thanks in advance!
    • TheCoder
      • Jun 2011
      • 693
      Originally posted by mtreams
      Hi Guys,
      That would depend on your provider and local area. Most providers segment their networks and transmit different frequencies in different locations.
      To find the proper frequencies you really need to capture and interpret the NIT tables for your local NetId. On a dreambox a program called dvbsnoop can assist you in this endeaver.
      • AVGAL
        • Jul 2011
        • 64
        I would have guessed you have a FY box. Problematic box. You wont get that channel. Even you manage to get it, it will drop.
        • SGDVB
          • 210
          This is the worst box ever... If you have already auto or manual scan 394, you should have it to the channel list but dun expect it to line up the new channel for you.
          The new additional channel will be added to the very last page of the list & oso there is no way you can move it forward or to assign a channel number.
          The editing function on this box is near zero & you can never self-help yourself other than to scan for new channel.
          If you wan the new channel to line up according to lcn, pray hard for new firmware update by the manufacturer.
          • mtreams
            • Jan 2013
            • 7
            Well guys thanks for your info, will try to scan it manual...see how it goes...
            • mtreams
              • Jan 2013
              • 7
              I'm able to get the Disney XD but not the HD...
              • hehaha
                • Jul 2010
                • 4
                Anybody owns a Sunray SR4 able to autoscan channels on the 2 new frequencies 394 and 458? Autoscan doesn't find any channels on these 2 frequencies at all.
                I'm able to add the channels manually, the EPG works correctly but no image is displayed.
                • ypvs125
                  • Dec 2010
                  • 506
                  Sr4 is a triple tuner of c/s/t. Make sure u r using the correct tuner.
                  • maelgeny
                    • Mar 2013
                    Hi, do you know the frequency for sg starhub? I did a auto scan but nothing came up.
                    the message shown as "all known transponders have been tried, but no lock was possible.verify antenna and cable"
                    Im using DM 500C, can u help???
                    Thanks.
                    • hehaha
                      • Jul 2010
                      • 4
                      I'm using the correct tuner. I'm running OpenPLi with the custom satellite configuration to scan cable channels.
                      Only the 2 new frequencies show no channels, all the others are working fine.
                      • ypvs125
                        • Dec 2010
                        • 506
                        Thanks.
                        If u r doing an auto scan, u need to have cables.xml. For complete list of channels, u can find yr answer here.
                        • ypvs125
                          • Dec 2010
                          • 506
                          For an updated channels, u can try the e2 bouquet here.
                          If u want to try sgsh channel update plugin maintained by uu161, u can find it here. Next time if there is a new channel added, run the plugin and the new channels will be added to yr bouquet.http://www.digital-kaos.co.uk/forums...gin-sg-286366/
                          • mtreams
                            • Jan 2013
                            • 7
                            Guys, For your info I'm able to manual scan Disney XD HD frequency 458...& also on this frequency you can get the Fox Sports Plus HD...
                            • mtreams
                              • Jan 2013
                              • 7
                              And comedy central HD
