tuxbox commander
  • papairwin
    tuxbox commander
    where i find tuxbox commander.
  • zubair4148
    • 11
    That's Plug-In,
    Download Via Blue-Panal.
    • icaicm
      • 100
      what image is on the box. usually its in pluggings which you access via pressing the blue button. if its not there then you will have to add it.
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        There's a few plugins here...
        Tuxbox Commander Useful for editing files on your dreambox. Dream Netcast Internet Radio Listen to internet radio on your dreambox. Edit the /var/etc/stations.xml file to add new radio stations. Dream Weather X Weather information DB Switch If you have two dreambox receivers in the same room you can use this to
        • nilrem
          • 54
          If your using a DW image it's already installed and accessed via the Yellow button
          Cheers
          • baggio
            • 11
            Cheers
            had the same prob as my image was an old one....had to update my image in order to get the tux commander.
            • rara925
              I'm using Commando 4 cos I've found it to be more stable than some of the later images but I want to install tuxbox commander. Where can I download it and where do I install it?
              Cheers
              • kos1977
                dreambox 500
                i mounted the folder to my db but i dont know how to find the plugin from thet folder in db and to instalit, please help
                • djrino
                  alot of tnx
                  • backa
                    • Feb 2010
                    I just can not connect the db500 on net to download the Tuxbox. Any help?
                    • funnos
                      • Apr 2010
                      I need some help also.
                      I'm trying to manually install the software by mounting a drive on my laptop, but the DB is not showing the files within my share.
                      Plzz help ...
                      • funnos
                        • Apr 2010
                        Ok, share is working thanx to all within this forum ...
                        When I install TuxBox, i receive the message that the installation was successful ... but the plug-in is not showing in the plugin folder ...
                        plzz help, i am a newbie with this stuff ....
                        • sunnysial
                          hi
                          thnks for sharing .,.
                          • aleezz1
                            • Oct 2010
                            how do i install a plugin? my dreambox 500's ftp password is not dreambox
                            • cloudnineuk54
                              • 530
                              have you tried commando
