Default password problem
  • Tinkerstar
    • May 2012
    DM500 Default password problem
    Hi all..
    I have this box which i been using for some time. I wanted to update the channel and I read through the forum on how to do it. I tried to access the box via ftp but it keep saying password/ login details wrong.
    I tried the default userid and password as below:
    userid: root
    Password: dreambox
    Think the software is written by sgdvb
    Anyone know the correct password from you or how can i go about flashing the box or updating the channel?
    Any help is much appreciated.
    Thank you
  • mticad
    • Jan 2013
    • 10
    Don't think u can ftp using default id/password as it's been changed since day one.. from ur seller.
    One way.. clean flash via null serial cable once u have the keys/scce files.
    rgds.
    • Bomchacha
      • Feb 2013
      • 117
      already pm you the details
      • Tinkerstar
        • May 2012
        Thanks bomchacha..thats the keys and scce files?
        I cant connect via dreamup. it says on ur dreambox. on already but nothing happens.
        since i do not have the password, will this hinder the flashing process.
        do u happen to know wat method should i use?
        thanks in adv
        • Bomchacha
          • Feb 2013
          • 117
          Answer is all here
          If you do not have a coms port for the null modem cable, then you need to buy a usb adapter for your null cable.
          USB Adapter can be bought from Sim Lim (Bizgram level 5)
          Null Modem cable can be bought easily from any shops which sells computer cables
          at Sim Lim
          • Tinkerstar
            • May 2012
            I have these..but still have problem..
            not sure if the prob lies with the usb thingy.....
            • DBTraitor
              • Feb 2011
              • 616
              yes, its the usb problem
              i suggest you go for what is recommended in the pic shown by Bomchacha
              A wise man learn more from a foolish question than a fool can learn more from a wise answer.
              • AJAXHAN
                • Apr 2013
                • 4
                don't flash other than windows xp. I've tried windows 7 and 8 but no result. cable can be bought at sim lim tower basement shop.
                • mitoev96
                  • May 2013
                  • 22
                  no wonder till now I cant and dunno how to flash as I am using win 7
                  • gohjh48
                    • Jul 2013
                    • 10
                    Originally posted by Bomchacha
                    Answer is all here
                    at Sim Lim
                    Hi Bomchacha.
                    I have similar problem as Tinkerstar and I had already flash via web browser.
                    Base on your advice, does it mean that flashing using null modem will reset the dreambox username and password?
                    Thank you.
                    • 2echo
                      • Jan 2012
                      Sorry to hijack your thread TS. You managed to find the password? I tried dreambox, 0000, 9999 and many others combination but to no avail....
                      • moviesg
                        • Jul 2012
                        • 60
                        Root
                        Dreambox insmall caps
                        If you cant remember just reimage will do
                        Sent from my GT-I9305 using Tapatalk 2
                        • Bomchacha
                          • Feb 2013
                          • 117
                          why do you need the pin where obviously you wont get it.......
                          either reflash an image without pin or do your channel updating via yellow button
                          Last choice, go back to your seller
