dm 800 hd se remote not working
  • pspmixer
    • Jun 2009
    • 750
    DM800 dm 800 hd se remote not working
    remote for box stop working today, I tried putting new batteries didn't work still, tried seeing if red light could be seen with camera on my phone and I could see it, any ideas now to sort this please. I know the dreambox control centre has a remote on it but id like physical one to work
    Try pressing the "dream" button then the "tv" button. or switching the box off from the back and on again ..
    • Elric
      V.I.P. soft lad
      • 853
      to check if remote is ok get a camara fone put it on camara while looking at the led thru camara
      the led should flicker when you press a button on remote
        He's done that duhh
        • pspmixer
          • Jun 2009
          • 750
          tried that didn't do nothing
          yes ive done that
          • pspmixer
            • Jun 2009
            • 750
            Originally posted by JoK
            When you press any button on the remote does the dream button on the remote flash ON/OFF with button presses?
            JoK
            yes it does
            • pspmixer
              • Jun 2009
              • 750
              all dreambox control centre remote isn't working now just shows as unrecongised webpage
              • AVGAL
                • Jul 2011
                • 64
                If you have your remote is dead then check these things...
                You can use a mobile fone camera to see if the remote is sending a signal...
                Turn on the camera on your phone
                Point the sensor of your remote to the camera and press every button of your remote control
                If the remote is not sending a signal it will look like this when you push a button on the remote: Image
                If the remote is sending out a signal it will look like this when you push a button on the remote: Image
                If the remote is not sending out a signal then check the prints on pcb if prints are ok then check the remote sensor .....
                • pspmixer
                  • Jun 2009
                  • 750
                  I got a replace sent to me free of charge from supplier I bought it off
