Channels
  • dan20leeds
    • 168
    Channels
    About to buy a dreambox, but how do i put channels on it?
  • badboy123
    • Apr 2009
    • 39
    you have to connect it up, put in your location and scan for the channels
    • dan20leeds
      • 168
      thanks, i dont need to flash any images whatever this means?
      • badboy123
        • Apr 2009
        • 39
        If your box is already flashed then no, but it may be that you have to flash your box...its not hard, very little chance of it going wrong
        • dan20leeds
          • 168
          thanks for your help. which box would you reccomend for easy set up and one that is probably already flashed? what does the flashing mean?
          • badboy123
            • Apr 2009
            • 39
            Flashing is basically putting on software on the box so you can interact with the box...all the boxes are pretty much the same in terms of set up because they all work in a similar way...its just depends on what you want and how much your willing to pay...a cheap basic dreambox 500c would probably cost you ?70 whereas the dreambox 800 which receives HD channels would cost you about ?450
