TX TO ALL THAT HAVE HELPED ME SO FAR , THIS IS MY 1ST ATTEMP AND THE HELP IVE HAD HAS BEEN 1ST CLASS
OK THIS IS MY PROBLEM I AM GOING TO TRY COVER EVERYTHING I HAVE TRIED, I HAVE FOLLOWED TUT TO FLASH BOX WITH IMAGE DK1.1. DONE A SCAN FOR MY AREA AND IT SEEMS TO BE A SUCCESS I AM PICKING UP FREE CHANNELS BBC ITV ETC SO I PRESUME THERES NOTHING WRONG WITH IMAGE AND CAN RULE OUT REFLASHING IMAGE? OR IS THIS AN OPTION?
MY SET UP IS D LINK ROUTER ,AND I HAVE NO PC JUST LAPTOPS USING A WIRELESS NETWORK WITH WINDOWS VISTA .I HAVE FOLLOWED EVERY TUT ON THIS SITE ON TRYING TO CONNECT DREAMBOX 500C TO MY LAPTOP USING CROSSOVER CABLE RJ45 TO RJ45, THIS IS MY 2ND CROSSOVER CABLE JUST INCASE 1ST ONE WAS FAULTY. I HAVE ALSO TRIED CONNECTING TO ROUTER WITH ETHERNET CONNECTION BUT KEEP GETTING SAME RESULT CONNECTION FAILED I HAVE USED 1ST FLASH FXP FILEZILLA, DREAMBOX CONTROL CENTRE, I HAVE PUT IN IP ADDRESS ON DREAMBOX SAVING AND UNCHECKING DHCP THEN CHANGING LAN SETTINGS INTERNET PROTOCOL TCP/IPV TO WITHIN SAME RANGE AS DREAMBOX .192.168.1.100 BUT I TRIED A FEW DIFFERENT IPS STILL CONECTION FAILED, I HAVE ENABLED ALL THESE FTP PROGRAMMMES ON EXCEPTIONS LIST SO ITS NOT FIREWALL.WHEN I CONNECT TO LAN NETWORK IT SAYS LIMITED CONNECTIVTY BUT THAT?S ALL I GET , I HAVE LATEST FIRMWARE ON ROUTER ,FEEL LIKE I HAVE COVERED EVERY POSSIBLE AVENUE I CAN TAKE UNLESS ANY OF YOU CAN SPOT SOMETHING ELSE I CAN TRY CHEERS IN ADVANCE STAGS
Whatever!!
