Some Distorted Channels in DM800HDSE
  • sujak84
    • Jan 2013
    • 36
    Dear Gurus,
    Recently, i am having problems viewing some HD channels such as channel 655 and 155. Is there anything wrong with my tuner or am i suffering from signal leakage?
    Pl advise.
    Thanks.
  • sujak84
    • Jan 2013
    • 36
    Ive sorted it out. The signal strength for most channels are around 93-95%. The distorted channels gave a strength signal of about 75%-76%. So i thought it is my Phillips Tuner and was looking around to change it to the Rev M tuner when suddenly I realised I was using a splitter at my TV point. I removed the splitter and my signal strength for the distorted channels boosted to around 87%.
    Problem Solved. No more glitches. Lesson to be learnt, do no use a splitter.
    • Bomchacha
      • Feb 2013
      • 117
      you can use a splitter provided you have a signal booster
      • madjack
        • Apr 2012
        • 28
        What signal booster do u recommend? Brand? Plqce that sell? Thanks
        • Bomchacha
          • Feb 2013
          • 117
          Sim Lim Tower got sell
          Go basement and ask around... its very common
          No particular brand to recommend, it shld all work the same
          Preferably look for one that has output of 30db
          CATV Signal booster / Signal Amplifier
          can be found on ebay or aliexpress
          • quest0126
            hi, how do i check the signal strength? I too have one channel having distorted...but most channel no issue...
            • AVGAL
              • Jul 2011
              • 64
              Recently, I have a few channels distorted and I decided to replace my splitter and the signal cable to SH quality one as I have been using my existing splitter and cable for 20 years. After changing all these, channels went back to normal.
              Actually 1 channel is distorted is not really a big issue unless you only like to watch that channel. You decide whether its worth it to spend the money.
