hi guy,s . i,m looking for your views on the quickest way to flash the 600 as its a pain waiting 30 mins with dreamup. if you could give a few details of what you found to be quicker.
quick way to flash
as ted says try telnet.
heres some instructions
Slightly different to other dreamboxes. You can either use the Dreamup software (takes ages) or use the method below instead.
1. Boot the box, goto the communication menu and note the ip address.
2. Run DCC, connect to the dreambox. Once the network is connected ok, click on the the 'Telnet' option.
3. In the telnet window, type the following, pressing <return> at the end of each line.
mount /boot -o remount,rw
rm /boot/*
reboot
4. You should now get a message saying that the Dreambox is rebooting.
5. Wait a few seconds and then run Explorer (Firefox or whatever) and enter the ip address of the Dreambox in the address bar.
6. On the screen that appears, choose the 'Upgrade firmware' option, find the .nfi file and click the 'Flash' button.
7. Once the progress bar reaches 100%, reboot the box
all done
PS3= krazylegz120282
if you like what people say please use the reputation or thanks button, dont just make a post to say thanksComment
thanks father ted and thank you krazylegz.as ted says try telnet.
rm /boot/*
reboot
all done
does this work for the 600? have you tried it ? is it tru the router ? straight or crossover cable? many thanks .is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.Comment
yes mate that is for the 600 and yes i've done 600's before that way.
you can either use it through router or crossover, i always just done it through my router as its always setup through thatPS3= krazylegz120282
I find that after I kill the bootloader in telnet and reboot the dm600, I always have trouble connecting to my box because the router always assigns it different ip address then previous to reboot the box. I always end up checking the dhcplist in the router to discover the new ip address to flash with the web interface.Comment
Last edited by alliv; 4 June, 2009, 23:44.is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.Comment
curious m8, thats exactly what happened to me.I find that after I kill the bootloader in telnet and reboot the dm600, I always have trouble connecting to my box because the router always assigns it different ip address then previous to reboot the box. I always end up checking the dhcplist in the router to discover the new ip address to flash with the web interface.is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.Comment
On your pc do Start > Run > type in telnet 192.168.x.xxx ip address of your dreambox
1. In the telnet window, type the following, pressing <return> at the end of each line.
rm /boot/*
reboot
2. You should now get a message saying that the Dreambox is rebooting.
3. Wait a few seconds and then run Explorer (Firefox or whatever) and enter the ip address of the Dreambox in the address bar. If you cannot connect to your dreambox than check the ip address of your dreambox in your router in case it has changed and type that ip address into your browser.
4. On the screen that appears, choose the 'Upgrade firmware' option, find the .nfi file and click the 'Flash' button.
5. Once the progress bar reaches 100%, reboot the boxComment
