I've bought one unit supposedly with autoroll keys installed. However, I suspect it is not installed. Inside /usr/keys only have a file constant.cw while /var/scce have a link to /usr/scce which does not exists. Does it mean I've been con by the supplier?
How to know autoroll is installed?
This topic is closed.
Important thing is whether u can view all paid channels. Autoroll might not work in the future and also no key changes for a long time. -
Unfortunately, I cannot view any paid channels. I'm trying to figure out if it due to the autoroll keys not installed, or the seller did not even provide me with any keys. The seller has refused to reply my emails too. sigh...
Below is some info
Enigma Version: Cnigma2 by ***21335;***20140;***20197;***19996;@freedmx
Image Version: Experimental 2011-10-22
Frontprozessor Version: V3
Webinterface Version: 1.6.6Comment
The seller has sold u a set without the keys installed.Unfortunately, I cannot view any paid channels. I'm trying to figure out if it due to the autoroll keys not installed, or the seller did not even provide me with any keys. The seller has refused to reply my emails too. sigh...
Below is some info
Yup the seller has con you.Unfortunately, I cannot view any paid channels. I'm trying to figure out if it due to the autoroll keys not installed, or the seller did not even provide me with any keys. The seller has refused to reply my emails too. sigh...
Below is some info
The least you should be able to do is to view the paid channels.
Maybe can share his contact info so that other people will deter from buying from him?Comment
DM800/800se only, ( i dont hv recent 500 to play)
Press blue, see only 2 cam installed, CCcam and OScam (sorry no mgcamd), the China boxes some may hv Sg keys pre-installed but not Auto-roll and must select CCcam to work. They said Sg never change keys, so save time dont install Mgcamd since both oso need to input keys. Once if they input Sg-mgcamd, the boxes cannot sell to other country, bcos emm stream different in every country so SG-mgcamd is no use to them. So they play safe.
My recent observation.
p/s: CCcam & Oscam r 4 cline, fline and Nline ready. When box arrvd from China, dont do anything but got setup to see that the DHCP is usually disable for manual config. Any Guru notice this is new DM800series?Last edited by jatrophaseed; 29 June, 2013, 03:59.Comment
