Help with locked freeview & other channels
  • gezoid
    • Jun 2009
    • 13
    DM600 Help with locked freeview & other channels
    installed the latest Enigma image, installed the cables.xml from here, installed the "fix for noobs" into /var/scee and copied over the k*ys (from another rapidfile download found here) to /var/keys, did a brute force scan and it found 300 odd channels. Then went to S*y Sp*rts 1 held info button for 3 seconds and restarted the softcam (from the menu) and rebooted box.
    Then deleted the contents of k*ylist.txt file and tried s*y sp*rts again, file not updated.
    All the scr*mbled channels are l*cked but also some of the freeview ones are. How do I fix this?
    In the menu there is an option for softcam but I don't know what settings to use or indeed if I need to use it. Any help you can offer would be appreciated
    THe softcam settings are
    Channel: Sky Sports News : Default
    Provider : nopig_56A : Default
    Default softcam : --None --
    Cardserver -- None--
    Auto reconnect and can handle two servcies are ticked.
    Is that right?
    Whats the differnce between softcam and evocam? Do I need evocam? Confused now!
    I'm pretty close and just need a tiny bit of help with the last bit.
    TIA!
  • Ebro
    • 67
    Yes you need to download and install a softcam. This will do your decrytpion or you. Use the blue button menu option to download.
    • gezoid
      • Jun 2009
      • 13
      AH! Thanks, funny the cams are not mentioned anywhere in the noob guides, ho hum. My box isn't connected to the internet, is there a manual method? I downloaded the evocam 2.17c and it says unzip and stick in tmp then use the manual option from blue button, tried that but nothing listed.
      So is there a manual method that works? TIA!!!
      • despdan
        • 544
        Is that right?
        You should set the Default softcam.
        What image are you using?
        what box?
        • gezoid
          • Jun 2009
          • 13
          Connected to internet and downloaded evo - thanks!!! All up and running. You guys rock!
          • Ebro
            • 67
            Glad you're now working. Welcome onboard.
