Gemini / cardserver
  • despdan
    • 544
    #16
    @manics
    check to see if libcamdio.so.0 file is in the var/lib folder.
    You can check to see if cardserver is working by starting it on its own.
    first set the cam to ci then use tuxbox commander to start cardserver if there is a problem it will tell you what line is wrong.
    Once you get it reading the card then start newcamd.
    It is cardserver.config you should be editing
