Dreambox DM500C please help
  • mcsuk
    • 4
    Hi people been trying now for about 3 weeks still no joy in getting it to work tried loads of images put the magic files were they suppost to go
    i dont get any ftv channels and the channel scans only show about 10 channels the epg shows whats on
    sometimes the picture starts to clears but doesnt
    im in mansfield on N+L any help on service files and all that greatly appreciated
  • MetalKettle
    V.I.P.P.T. Member
    • 797
    What setup do you have? Do you have a cable modem, subbed box? Is your signal split in any way?
    XBMC/KODI Developer
    • mcsuk
      • 4
      setup
      hi
      yes i have a cable modem
      the cable comes in the wall then is split one for the modem the other for the box
      • MetalKettle
        V.I.P.P.T. Member
        • 797
        Originally posted by mcsuk
        hi
        Try removing the splitter. Plug the Dreambox directly into the wall and try scanning again m8.
        XBMC/KODI Developer
        • ManofScience
          • 650
          try it on the direct need from the wall, no splitters -just to see if it can get the channels
          • netpilots
            • Jun 2009
            Gemini or some other Software
            I used Gemini 3.6 3.8 or 4.x to make the DM500C working with Nagra. Still looking for a solution to make Conax working.
            • mcsuk
              • 4
              direct no splitters
              ok guys done the no splitter scan
              found 280 services etc
              got some ftv channels running
              none of the channels with thew lock symbol are viewable just a black screen all the epg is there
              any ideas
              • MetalKettle
                V.I.P.P.T. Member
                • 797
                any ideas
                What Image you using?
                Have you transfered the magic files and the Nov2008 fix to the box?
                Have you started the emu?
                XBMC/KODI Developer
                • mcsuk
                  • 4
                  using dk1.1
                  using the dk1.1 image and have started the emu
                  not sure about the fix
                  what files are in the fix
                  • MetalKettle
                    V.I.P.P.T. Member
                    • 797
                    The fix contains new rom files.
                    See here mate
                    XBMC/KODI Developer
