370Mhz PRoblem?
  • croc
    • Jul 2012
    • 70
    370Mhz PRoblem?
    Hi all ,
    do you face any problem accessing like HD5 , HBO HD or HBO Hits HD?
    Have tried rescan but sometime worse cannot get channel...if get channel either distorted or missing totally
    i have another black HD800c but no problem on the signal
    problem one white FY-888
  • TheCoder
    • Jun 2011
    • 693
    Its probably a marginal signal at that frequency. Things like loss and noise are very frequency dependant so its quite possible for you to suffer a 'notch' effect whereby the level you see at the equipment for that frequency is somewhat lower than other frequencies. It may also be that the actual transponder is transmitting a lower signal level.
    The fact one box see's a signal whilst the other doesn't isn't really indicative of a fault - merely that one tuner is slightly more sensitive than the other. Generally sensitivity of individual tuners can vary by as much as 1-2%, even within the same batch.
    • jatrophaseed
      • 589
      Master Coder, I seldom see on in this Sg threads??? Welcome to Sg scene.
