BPL Channels on MVHD 800C VI Wifi
  • Kikino
    • Aug 2012
    • 13
    #16
    For those who has problem watching BPL channels on MVHD VI .
    What I did.
    Reset factory setting."Yes"( MVHD VI Model )
    Page will reload to menu page.
    Do manual scan one at a time.Continously without exit the page.QAM 256
    13500/6090 PG 226 -228(This FreQ.works well on this model)
    12850/6090. PG 229 -231
    14950/6090. PG 232 -233
    Exit that page and go to Channel List Page and "Delete All"
    Lastly Auto Scan to search for all channels.
    The channels number will be in sequence.
    Do it step by step and you won't go wrong
    Hope this help.Enjoy..
    • kangjihh
      What I did.
      hi bro, may i know what fw are u on?
      • hobbito
        • Aug 2013
        thanks bro this works. the problem frequency is 13500mhz. it should not be 13550mhz, else the picture will be distorted.
        What I did.
        • Kikino
          • Aug 2012
          • 13
          #19
          Hi im using...( SCV_HDC3000L_M_L1.1_V2.5.0_CID-21009 )
          Using diff FW can cause ur set to hang and lost of signals.Cant detect any channels when Auto Scan.
          Beware always check with your agent or seller before upgrade and flash..
          • jamal_jantan
            • Nov 2010
            • 7
            #20
            What I did.
            Yes,
            I agreed the above information. I have done on my MVHD box.
            Doing fine till yesterday nite.
            • sinhwa
              • Aug 2013
              #21
              I flashed the firmware to (SCV_HDC3000L_M_1.1_V2.5.0_CID-21009). I think I bricked the MVH 800c-vi wifi box, cannot switch on anymore, always on standby mode, it was previously on v2.4.5. It is the correct box and nothing went wrong during the flashing. Any recovery method for this?
              • Kikino
                • Aug 2012
                • 13
                #22
                Did you reset factory setting before you upgrade/flash? Your firmware looks different with no L1.1... Not sure with or without L plays apart..
                Try manual OFF and ON by Controller.. Not working?
                Try hold the power button for few secs then power OFF from the power supply, then ON again.. Still not working?
                Send back to Agent..
                • sinhwa
                  • Aug 2013
                  #23
                  it's with L1.1, typo. firmware is same.
                  I didn't reset to factory setting before flashing. Didn't know need to do that.
                  • Starfug
                    • 6
                    #24
                    I am unable to scan channel 232 and 233 with freq 14950 Any idea why? Any gurus can help?
                    • viperjet
                      • Dec 2011
                      #25
                      Same here... manage to get 226 to 231 but unable to get 232 and 233... anyone can advice?
                      • Kikino
                        • Aug 2012
                        • 13
                        #26
                        Try to follow post #16.... It happened to me when i do this steps all back to normal.. Good luck guys!!
                        Happy watching!!
                        • Andylim80
                          • Oct 2011
                          #27
                          Hi Guys i just bought the MV HD 800C-VI one month ago.At first the mio bpl channel are working fine.But suddenly this few days all the mio bpl channel can't watch...when even i switch from a working channel to bpl channel it hang there with a small square blue logo with a word(scrambled).any one know what happen?I try #16 method but it didn't work...Please help!!!
                          • eskedumdes
                            • Oct 2013
                            #28
                            I think they block the signal already.. haiz.. watch at coffeshop from now on..
                            • moronicgenius
                              • Jun 2012
                              • 54
                              #29
                              yes N3 oledi other channels following soon... enjoi while it last
                              • DBTraitor
                                • Feb 2011
                                • 616
                                #30
                                Those using dreambox and Q5 will not have these issues
                                Now you know why cannot anyhow buy box
                                Other clones are not the way they claim it to be
                                A wise man learn more from a foolish question than a fool can learn more from a wise answer.
