munchkin can't connect to dm
  • munchkin59
    • Jun 2009
    • 25
    having the same problem, juist flashed it ok with DK v1.1
    no problem.. disconnect from pc, then reconnect, open filezilla, just keeps searching and re searching... any help please..
    what is DHCP? were do i find it..
    silly question do i connect the dream box to the tvg at the same time as pc
    or is it just pc--dream box
  • caveman_nige
    • Feb 2008
    • 4920
    i need to move your post to its own thread and will answer it there...
    OK moved here....
    what method did you use to flash the dk image onto it?
    btw way.. DHCP explanation here >>>>>>>>>> http://en.wikipedia.org/wiki/Dhcp
    Last edited by caveman_nige; 11 June, 2009, 23:49. Reason: post moved to own thread
    • munchkin59
      • Jun 2009
      • 25
      pc connected to dreambox. using a crossover cable..use dream up
      Just will not connect
      PC is wireless connection on VM
      • caveman_nige
        • Feb 2008
        • 4920
        ok you will now need to connect agin with the crossover cable if your are not using a router. find the ip address of your pc and give your dreambox an ip address inthe same range i.e
        pc is: 192.168.1.4
        make dreambox : 192.168.1.5
        to get to the ip of your dm go into the menu on your dreambox, scroll to setup then scroll down to expert setup,then communication setup, theres your dream box ip, write it down and go back to your ftp prog and try it
        enter your ip into the server or url box.
        under user name enter root
        under password enter dreambox
        click connect.
        • munchkin59
          • Jun 2009
          • 25
          pc ip = 86.4.7.150
          B/B ip = 192.168.0.1
          is this right
          • munchkin59
            • Jun 2009
            • 25
            ok have checked via my computer not one of those sites(find my ip) it is 192.168.1.6
            • munchkin59
              • Jun 2009
              • 25
              pc is: 192.168.1.4
              click connect.
              tried this till no conection
              • caveman_nige
                • Feb 2008
                • 4920
                have you switch off any firewalls you may have active on your pc?
                • Curious123
                  • 2591
                  Originally posted by munchkin59
                  pc ip = 86.4.7.150
                  is this right
                  If your pc ip address is 86.4.7.150 than you need to untick DHCP on your dreambox and probably make the ip address of your dreambox as 86.4.7.151 if you are still using a crossover cable. Try doing this to see if you can connect to your dreambox.
                  • munchkin59
                    • Jun 2009
                    • 25
                    totally confused sorry.. have managed to connect d/box to pc to flash it but cant connect to add keys.... ?
                    does the d/box have to be connected to the router at the same time as pc or what
                    what is the sequence... pc to d/box to router
                    pc is wireless down stairs router and modem up stairs does this need connecting to my pc.
                    just cant seem to get a grip on this at all
                    really sorry
                    • westkill
                      • 2378
                      only need to connect dreambox to router with ethernet or cross over cable
                      only need to connect to pc if no router
                      find the local ip address of pc example 192.168.001.100 will start this ,then go to dreambox set the ip address 192.168.1.10* the last number being different 1 up to 9
                      • munchkin59
                        • Jun 2009
                        • 25
                        ok if i connect the dbox to the router, the internet down stairs cuts off..........
                        • westkill
                          • 2378
                          how many ports are on the router there should be spare ports on the back
                          • munchkin59
                            • Jun 2009
                            • 25
                            four spare, dont use any at all........
                            • westkill
                              • 2378
                              stick the ethernet i mentioned into one of those ports and into your dreambox to make networked dont have to unplug the main one for the internet
                              then set the ip addresses as mentioned
