no setanta after scan today
  • loncell
    • 625
    DM500 no setanta after scan today
    just scanned and i cant get setanta 1 + 2 .i've bruteforced but still nothing i did notice that Sky Sports 1 shows nr 90% sig but on setanta its 60% but no picture or sound.
    i know they went dow nthe other week and a scan found them but not this time.
    anyone any idea's ?.
    oh and disney as well , prob on same transponder.
  • alexh
    • 225
    There are no channels on the transponder frequency that used to be Setanta in your area.
    All you can do is try a network scan:
    1) Switch to a root channel (DL *******)
    2) Press menu, Setup (5), Service Searching (2), Manual Transponder Scan (2)
    3) Tick the INV box
    4) Tick the Network Scan box
    5) Press scan (green)
    Wait 10 mins or so until scan finishes.
    Check your ALL SERVICES list.
    This is an alphabetical list which should start with 4Music, Adult Channel etc. etc.
    If you have any channels listed BEFORE 4Music select one and wait a while (even if there is no picture). Bring up the ALL SERVICES list and it should have updated.
    Repeat until 4Music is the top channel.
    I dunno about step (1) but the rest is sound.
    • loncell
      • 625
      what do you mean :-
      1) Switch to a root channel (DL *******) ?.
      and has it reappeared for you using this method ?.
      • alexh
        • 225
        Originally posted by loncell
        what do you mean :-
        I mean switch to a channel which starts with the letters "DL"
        i.e. "DL 2100 Samsung G1"
        There will be no TV on this channel, but by switching to that channel you setup the Transponder frequency to one that should contain all the PIS information about how to find all other Transponders.
        I never do Automatic scans, I've always done network scans.
        A network scan looks at the NIT/PAT/PMT tables for the current Transponder and tries to find all other transponders and their corresponding channels from this data. If the NIT/PAT/PMT tables are correct, it should be easy for it to find all channels.
        I had never heard of turning to a "root channel" before performing a network scan but I read about it this week.
        It makes sense, if you perform network search from the transponder with say "BBC One" it has no knowledge of one or two transponders.
        • loncell
          • 625
          you seem very knowledgeable about dreamboxes and i've played with my fair share but im still baffled with when you say :-
          " I mean switch to a channel which starts with the letters "DL".
          were am i looking for this ?. in all services ?.do you mean say channel called " flash service 69" or summut and scan from there ?.
          • mark015
            • 254
            just go into set up service searching /manual scan tic inv box tick use bat tick use network tick use onit then do ur scan,worked for me earlier .i couldnt do a brute force scan also so just did a manual scan as ive said above,,and u will also find DL 2100 /DL 2110 /DL 3110 IN ALL Services,hope this help you out.
            • alexh
              • 225
              where am I looking for this ? In all services ?
              Yes, all services list.
              Yes I guess. Are the channels are listed differently in different regions?
              • loncell
                • 625
                right sorted chaps thanks for that , new one on me the manual scan .always done a bruteforce and its always done the trick so we all live and learn,thankyou.
                • alexh
                  • 225
                  Glad it worked.
                  Channel scanning software is not great in all Enigma images I have tried, especially on VirginMedia.
                  I think it is because VM is a closed network, no-one should be using anything but their boxes and so they do not need to follow the spec 100%.
                  Or it could just be shit code in Enigma that never gets updated.
                  • mercenary
                    • Jun 2009
                    • 48
                    I agree Alexh, but what is the best image then for VM? im using PLi, it works ok, get 99% of the channels i think, but the EPG doesnt seem to cache correctly.
                    I am thinking about moving image but have no idea which to try out now,
                    i got a DM800
                    • lfc4life
                      Sports Nutter
                      • 3200
                      tried brute force?
                      IM SORRY but i will never have any sympathy for maggie thatcher .... the bitch
                      I WOULD STILL LIKE TO SAY MY HEART AND RESPECT GOES OUT ALL BRITISH AND ALL ARMY TROOPS FIGHTING THE TERROR WHICH STILL BREEDS IN THE WORLD!! YOU HAVE AND ALWAYS WILL HAVE MY UTMOST RESPECT !
                      YNWA!!!
                      JUSTICE FOR THE '96"
                      "People say football is a matter of life and death. I'm disappointed by that approach, I believe it is much more important than that - Bill Shankly" -
                      YNWA
                      • alexh
                        • 225
                        How long is a piece of string?
                        From what I can tell all images are based on one of two Set-top-box code bases : Enigma and Neutrino.
                        Then there are 10's of different images of each and different builds of these images for different boxes.
                        Most have just been slightly customised to add gfx etc. but some have added value. Determining what that is, for each build, is difficult.
                        I am pretty sure there are patches which must be made to cable builds before they will work on VM. What they are and what they do I dunno.
                        I thought that PLi was not an image but was the name of a team which makes images?
                        i got a DM800
                        On VM? You got more money than sense.
                        If you have a DM800 then you got PLi Enigma2 Jade2?
                        • mercenary
                          • Jun 2009
                          • 48
                          Yeah im running PLi Enigma2 Jade2
                          i got the DM800, caus its got the HD, and i may buy a sat tuner for it in the future.
                          what Neutrino images work with the DM800? maybe i should give em a try
                          • alexh
                            • 225
                            i got the DM800, cause its got the HD
                            But there is only one VM HD channel and that is not on all the time. By the time HD is on VM, prices will have dropped so much you could have bought a DM500C while you were waiting, then get a DM800 and still have change.
                            Non AFAIK. Enigma2 or nothing for DM800.
