Racing UK / ITV2 / Eurosport
  • cmcdermo73
    • 22
    I don't get these channels plus others, any reason why? Is there anything i can do to get these channels?
    Just for info I get SkySports/movies etc ok.
  • aftermath
    • 4345
    you could try a signal booster from argos or somewhere, that most likely will sort it.
    • cmcdermo73
      • 22
      I have signal booster....... these channels don't even show up in my tv list
      • aftermath
        • 4345
        Are you running off a splitter ?
        if so try just connecting to main outlet, with no splitter. and re scan.
        whats your signal strengths ?
        • cmcdermo73
          • 22
          Not sure what a splitter is (sorry for my lack of knowledge).
          I have aerial that goes to signal booster then in to my dreambox.
          Signal strength is around 95% on most channels.
          • aftermath
            • 4345
            did your box come to you with image on?
            if not where did you get image from ?
            and where did you get the services file from ?
            • Devilfish
              Administrator
              • Feb 2008
              • 7872
              A splitter looks like this...
              Disconnect all splitters and connect it to the main feed that comes into your house. Try doing a new scan and see if the channels appear. If not, try connecting the booster again and do another scan. Play about with the gain control on the booster doing a scan after each adjustment.
              • chub32
                • 40
                not sure but for what ever reason all bbc channels plus some others went, tried evrything but nothing happen, when i was about to give up all came back on!
                • aftermath
                  • 4345
                  Sounds like the Dreambox fairy`s have been up to their tricks again. .
                  • Devilfish
                    Administrator
                    • Feb 2008
                    • 7872
                    I've always said that if something funny has happened and you haven't touched it, leave it for 24hrs to see if it rectifies itself. Most of the time its the cable company playing about. If it's not fixed after a day, then you can rip it to bits .
