500c cam help?
  • spider man
    • Jun 2009
    • 49
    #16
    I haven't ftp the cam. ..
    • spider man
      • Jun 2009
      • 49
      #17
      what is the point to provide the info in stalments?
      there is no options at DK1.1 to change the settings to 755!
      • Donnie Darko
        • 442
        #18
        Right click the file and change chmod attributes to 755
        Checkout the RED stickies massive amount of info and effort been put into them.
        • rajmadaher
          • Oct 2008
          • 21
          #19
          YOU MUST HAVE 213
          You must install 2.13 cam
          Then it will CLEARperfectly
          FORGET about keys they get updated automatically
          as long as you have auto update file in the var key dir
          Make sure rom files are CHMOD 755
          Then EVO scan
          WAIT
          sly sp*rts
          • rajmadaher
            • Oct 2008
            • 21
            #20
            you have to do it with your ftp software
            • spider man
              • Jun 2009
              • 49
              #21
              I may look stupid but i think there is a communication problem. how can I give a right click in my remote control? That is how I installed and activated my evocam. I used FIlizilla do upload the rom(keys and scce) to my dreambox. Could you be more specific about where do I have to change the settings? CAn I locate the com whit filezilla? and how?
              • Donnie Darko
                • 442
                #22
                You use the ftp client,not the remote.
                • spider man
                  • Jun 2009
                  • 49
                  #23
                  Just double checking are rom files Keys and SCCE?
                  should the rename each of these folders CHMOD 755? and drag them into keys and SCCE folders from the dreambox?
                  • Sirus
                    • 340
                    #24
                    Are you still abit confused about folders if so ... when you get the fix files from here you should have two folders SCCE and KEYS.. you can either put these 2 straight on the box via FTP and over write the prev folder or just move the contents from these to the already SCCE/KEYS on yer box
                    SCCE folder for roms(nagra stuff)
                    KEYS folder for the key filesi
                    To chmod... Right click a file thats on your dreambox as your viewing it in filezilla then a menu will come up go to file attributes the n change the 3 digit number to 755
                    EDIT -IF your still having probs and have a Null modem cable then visit this thread- http://www.digital-kaos.co.uk/forums...om-keys-35824/ and get Gazza2008s file and flash it using dreamup with the Null modem cable and say NO to flash erase... when its on your box do a bruteforce scan to get your own area chanls and set up your own bouquets then see if it clears any chanls(leave on Sly Sports for a minute)... if it doesnt then go on the server and get a few different versions of evocam and try them
                    • ashb
                      • Jun 2009
                      • 9
                      #25
                      Make sure you get the latest roms from here, RapidShare: Easy Filehosting,
                      Then connect to your 500c via ftp and delete all of the files in /var/scce, then install the files in the above rar into var/scce and set the files to 755 permissions. Not sure if every file in there should be 755 but it worked for me and can't see any harm in doing them all.
                      • spider man
                        • Jun 2009
                        • 49
                        #26
                        ok. but what about the keys? why should i only replace the scce?
                        • yousuf7694
                          • Jun 2009
                          A Step byu step guide would be very useful.
                          • ashb
                            • Jun 2009
                            • 9
                            #28
                            Here's what I did - I followed this guide word for word - Digital Kaos - Downloads - Noobs guide to 500c
                            I then replaced all of the files in /var/scce with the ones from here RapidShare: Easy Filehosting, and set the permission on the each file within /var/scce to 755 (basically gave each file the execute permission) - you should be able to do this by right-clicking on each file and changing file permissions should be one of the options on your FTP software (can't be any more specific than that as you could be using any one of hundreds of FTP packages.) This is the guide I followed to replace the /var/scce files, so if you need more info on that I recommend you download this - http://www.digital-kaos.co.uk/forums...box-noobs-429/
                            After replacing the files in /var/scce mine started working perfectly. Hope this helps.
                            • WILLIAM_G
                              #29
                              i would love to be able to download the files i need but cant seem to download at all
                              • spider man
                                • Jun 2009
                                • 49
                                #30
                                This box must be defect..... Send back to china is not the best option. The process of setting up a dm500 that I saw at "you tube" and that I read here seems to me very,very simple however box still not open channels apart from freeview. However I am confused becouse I read somewere that the DM500 settings are not simple for begginers. Still not sure what else could be....
