Connecting laptop to dreambox via crossover
  • erukus
    • 96
    Hi this is my first post.
    After spending a day or two trying to setup my communication using the apparatus detailed in the title of this post. I stumbled across this guide _http://www.dreamboxtips.com/tag/ftp/ written by your site. I followed it blindly and to my delight i had communication with my dbox I was able to put box ip address in web add bar and communicate via ftp.I loaded cccam 2.08 and installed it after that I turned off my computer and went to bed then today i try to connect no good have tried rebooting everything checked all ip address are the same as yesterday when i could connect. Could it be to do with the cccam i installed i have since deleted it and still nothing any help greatly appreciated.:
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Try disabling all other network adapters except the one you're using for the dreambox.
    Double, triple check the ip addresses, don't assume any parts of them are correct.
    If still no luck, do a factory reset on the dreambox (Menu > Setup > Expert Setup > Factory Reset). Setup the ip addresses again and try to connect.
    • smirnoff_rules
      • 8603
      my 600 sometimes changes its ip and l have no idea why but the mount its always fine , it will have only change a little at the end . 103 will change to 107 and so on , the 500 has been fine ?
      • erukus
        • 96
        Have tried all the above now did a factory reset and still no good i cant understand it. It was working perfectly yesterday? Is the next thing to reflash or does it seem it could be something else?
        • erukus
          • 96
          Ok reflashed box tried to connect to box with flash ftp first time nothing then it worked. im happy its working but i dont know if it was something to do with my install of CCcam im not sure i did that correctly, is it a faulty connection in the box, is it my crossover cable or is it something to do with the compatability of dbox 600 gemini 4.3 and cccam 2.08 that caused this prob just hope its not a hardware issue with box
          • kagon
            • 140
            I'm using pretty much the same setup and I've never had a network connectivity problem.
            Static IPs?
            PC(192.168.0.1)-->Dreambox(192.168.0.2) or something similar?
            If you've set things up using DHCP the IP addresses are never guaranteed to stay the same.
            • erukus
              • 96
              im using static ip not dhcp
              Ok i have had same prob again i.e. not being able to communicate and I had to reflash again.Working again I had to think to myself what did I do in between it working and not working and the only thing I did was to flick around with the camd setup so it must be something to do with that that is stopping it from communicating. I will have to figure out how to setup camd properly can anybody shine any light on this and know how camd setting would stop communication????????What is the correct way to setup camd and CCcam? Cheers
              • jimbo69jones
                • 64
                I know this might be a square brick in a round hole kind of solution, but one non-the-less that would work for you.
                Setup a dhcp server on the network somewhere, and assign a static IP based on the dreamboxes MAC address. Set the dreambox to dhcp and you'll have the same IP everytime on the dreambox. Not a very elegant solution, but it would work.
                • erukus
                  • 96
                  i dont think its a prob ith changing ip it seems that if i try to configure cam or restart/enable default cam it stops communicating?
                  • kagon
                    • 140
                    That just seems awfully strange. The softcam is just a process running on the Dreambox, it's not something that fiddles with network settings or does invasive things to the hardware. I certainly believe you when you say you haven't done anything other than adjust softcam settings but the cam modifying network settings or otherwise disrupting network connectivity on the Dreambox seems a bit far fetched.
                    • jimbo69jones
                      • 64
                      Theres other hocus pocus and black magic going on there somewhere alright IMHO.
                      • erukus
                        • 96
                        I have just realised that it is when I ftp anything to the box the ftp program says ok complete then I rebbot box and when i try to connect it says error with network i then have tried everything to communicate with it. checked all ips rebooted windows ,box everything. The only way I will be able to get the communication working is to reflash this has happened three times now. Do you think its the box should I have it returned????
                        • jimbo69jones
                          • 64
                          I would. Put the original image it came with back on the box. The first thing they will usually fob you off with is your image is the problem.
                          • erukus
                            • 96
                            jimbo how do I put the original image on there?I bought the box from mark hemmings satstore he is one of the official dream dealers so it shud be legite but maybe there is a prob with the image. Somebody alerted me to the fact that i need to chmod files to linux which i hadnt done and after doing that 755 it seems to be okay maybe that was prob i will wait and see if it happens again i will return box
                            • karlk75
                              • 10
                              hi guys was programming my dm7000s yesterday and when it was writing ccramps it was at 11000 and was taking a good half hour i know when i was prog my dm500 it only took 2mins anyhow i disconnected the power and turned back on i cant get into the receiver, on the display it just says dream multimedia ive got myself a crossover cable but what program do i use to get it going again thanks basicly at the mo it has no ip address thanks
