PinCode Help !!
  • rage99
    DM500 PinCode Help !!
    I have a 500plus
    I accidentally set a lock on the setup menu and the pincode for some reason is not 0000
    I have never setup a pincode but now its locking me out.
    I seen the guide on how to convert it from hex to dec.
    all i see is... setuplock=ffffffff
    and not something like " 00005ea6 "
    HELP !!!
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Edit the file with a value that you know, i.e. a pin of 1111 will be 457 in hex, so edit that line to read setuplock=00000457 then save and ftp back to box. Unplug the box, wait 10s and power up, try again.
    • rage99
      Did not work
      It just changed back to... i:/elitedvb/pins/setuplock=ffffffff
      I only restarted enigma, could that be problem ?
      <--rage99 added 179 Minutes and 58 Seconds later...-->
      Managed to fix
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        How did you fix it then? It could help others with the same problem...otherwise this is a useless thread!
        Try unplugging the box after editing the pincode.
        • ondejr
          • Jun 2011
          YES! All Right!
          I wrote in portuguese language... I am Brazilian. I have the solution.
          Acesse a "dreambox" via ftp. Encontre o arquivo config na pasta "/var/tuxbox/config/enigma".. e onde est? "pin/setuplock=ffffffff", apague o ffffffff e escreva por exemplo "000004d2" e a senha ser? "1234". Quando voc? escrever, salve e n?o reinicie a "dreambox". Com a caixa ligada, desligue o plugue e espere 20 segundos. Ligue o plugue novamente, e sua senha ser? "1234"... ALL RIGHT!
          • akgupta58
            • Jul 2011
            I have the same problem. Have a DM528S. The setup password is locked. Cannot acces it. Please tell me how to find out setup password. I do not have tux commander. Can I install tux commander on my box without having setup password. HELP please
            Originally posted by rage99
            I have a 500plus
            HELP !!!
            • winnetoe
              • Jul 2011
              treu root - dreambox
