can anyone get sbo on dbox 600c pvr
  • mab88
    • 37
    can anyone get sky box office on a dreambox 600c pvr
    i have tried all the things around to maunaly do them and none have worked
    i got told in other forums that they only work on the 500c
    if anyone can help me get it i would be very greatful
    i am in liverpool and i use to be on
    tele - west
    i am now on
    vir--gin me--dia
    if any of this helps but i would like it i missed the hatton fight witch i was gutted about so please anyone
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Try this way...
    FTP to your box, go to the /enigma/cable folder where your userbouquet files are stored. Right click each one in turn then select 'view', you're looking for the SPORTS bouquet, it will say so at the top. Once you find it, close it, right click and select 'edit'. Add these lines to the bottom of it.
    #SERVICE: 1:0:1:6a4:7:f020:0:0:0:0:
    #DESCRIPTION: Sky Box Office Sports
    Close and save file.
    Reload channels on your box or paste this line into your browser.
    (replace ip address with your own)
    See if that works.
    P.S. above info is only for ex-tw areas.
    • mab88
      • 37
      yes it worked thank god
      i thank you so so much i can watch da repeat now
      will this stay here now or will it go off
      btw it says unkown channel as channel name should i change anything
