dreambox 800c hd
  • mab88
    • 37
    dreambox 800c hd
    hi
    does anyone no what hd channels you can get on the db 800c hd and if it is worth upgrading to one
  • cgscott
    • 3513
    BBC HD is the only channel the uk cable company supplies at the moment although they have said by autumn there should be up to 5 channels!
    wow!
    I don't think its worth it really.
    Patience is a virtue.
    • mab88
      • 37
      thanks for the reply that poo then and with cable maybe going off there maybe no point or is it fixed now
      • cgscott
        • 3513
        What do you mean off?
        If your referring to your box what you got?
        • mab88
          • 37
          no i have the db 600c but someone told me cable is turning to different encryption
          • alexh
            • 225
            He's referring to the possible migration to the (afaik as yet unhacked) Nagra 3
            • mab88
              • 37
              yes i am going on about nag3 and i guess not been fixed as of yet then
              • petermiller
                • 10
                how to flash 800c hd
                how do u flash the 800c hd is it any different than flashing a 500c
                • westkill
                  • 2378
                  you can use dreamup which takes about an hour
                  or
                  • alexh
                    • 225
                    Considering the possible introduction of Nagra 3 (which would mean an end to using Dreambox's on the cable network) is it a good idea to buy an expensive cable DM800HD?
                    A DM800HD sells for roughly ?330 right? For the same money you could easily buy a HTPC with HDMI out and a HD capable PCI DVB-C cable tuner card.
                    i.e. AMD 785G IGP motherboard + Sempron 140 for under ?100. A HTPC case, 2GB DDR2 memory, SATA hard drive & HD capable PCI cable tuner card would be well under ?230.
                    Not to mention it would be hundreds of times faster, include everything a normal PC does, a web-browser & ability to play 3D games etc. all through your HDTV
                    • john8867
                      • 152
                      Alex, excuse my ignorance but what is a HTPC?
                        Home theater PC - Wikipedia, the free encyclopedia
