G-Box 2.25d
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    G-Box 2.25d
    G-Box version 2.25d.
    Tested on ex-tw and AU fine.
    Unzip and copy .tbz2 file to /tmp folder.
    Install via manual install option in Blue button menu.
    Enjoy!
  • justys
    thank you
    thanks for the gbox
    • C64
      • 2394
      Any new satellite changes mate?
      • Jonny_doe
        • 35
        Sorry to drag this post back up from the dead , but can this be installed in the new DK image ???
        the reason i ask is that every time i fxp the .tbz2 file to /tmp folder, then go into install add-on locally there's nothing there .
        • smirnoff_rules
          • 8603
          if your box is connected to the internet then yes its in downloads in emu on the image
          • Jonny_doe
            • 35
            When i go to download from server , i only get the choices from CCcamd , and Evocamd , no gbox , that's why i wanted to install manually ..
            • smirnoff_rules
              • 8603
              press up m8 there all there
              • Devilfish
                Administrator
                • Feb 2008
                • 7872
                Yes there's 3 pages of emu on the server.
                But I've just tested it and it won't install a manual install if it's a .tbz2 file. Rename it to .tar.bz2 and it will work ok. I'll fix that for the next version.
                • Jonny_doe
                  • 35
                  M8 , what a plank i am , i never noticed the scroll bar on the side ,
                  sry for the stupid question , doh (homer moment)
                  Many thanks guys
                  • ruprect
                    • 58
                    Can this be put on a dbox? (if so where?)
                    AU is working with the patched rom7 files?
                    EDIT: I know see this was posted back in feb, probably will not keyroll so.
                    • shqiptaria-gbox
                      • 5
                      Gbox
                      Enjoy!
                      Gbox 2.25d frezeng after 30 min ??
                      • Donnie Darko
                        • 442
                        As already posted will this AU with the latest roms?
                        Checkout the RED stickies massive amount of info and effort been put into them.
                        • peter_022
                          • 8
                          Does this also update the roms?
                          Thanks in advance
                          • Jonny_doe
                            • 35
                            No m8 , you have to manually update the keylist file , or use the plugin to copy over the keys from Evocamd to G-box ..
                            • Rehan
                              thank you, i will try, Devilfish
