Err01 NO CA FOUND Help please!!!!!
  • marcelocwb
    • Apr 2013
    • 7
    Hi my Dm 800 hd
    sim 2.10
    clone
    error no ca found
    got error ca no found when flashing image .nif
    Tried dreamup v1.3.3.11,patched but say file too big for all files
    tried optiflash ,NCF photo.JPGbut when ask to turn on DM, not happens, I use Null-Modem-Cable, I have checked port Com, is fine,
    Don't have access to ip
    help please
  • satsmo
    • 6397
    Take a look here http://www.digital-kaos.co.uk/forums...-found-261618/
    • fooklee
      • Nov 2010
      • 17
      Search for my posting on No CA Error. you should have the solution
      • marcelocwb
        • Apr 2013
        • 7
        Hi there thanks for your reply, but my dm800 still no work
        • fooklee
          • Nov 2010
          • 17
          Try this.. read from some where
          ******REMOVED LINK TO FORUM OF SIMILAR CONTENT - READ OUR RULES AGAIN - LINKS GIVEN ALREADY PROVDE THE INFORMATION REQUIRED******
          Dreambox 800hd not responding to dreamup see below:
          Requirements: Null modem cable
          Procedure (With XP and hardware serial port)
          1)Ensure dreambox is unplugged
          2) Connect dbox to com port with NULL MODEM CABLE, do not try using a gender changer on a standard usb/serial cable. (Should be com1)
          3) Fire up Hyperterminal create profile using profile
          connection 115200 8 none 1 none
          4 Click ok to activate should see a flashing cursor in hyperterminal
          5 Power up Dreambox, wait few seconds and hit the 'f' key.
          You should see the 'Err01 no Ca found' dissapear, a few lines of garbage appear in hyperterminal window and dreambox loading onto 'STOP' looking for DHCP assigned IP.
          IP should be displayed shortly after where you can follow many other procs on here to access http://<displayed ip> and proceed with loading the correct SSL image.
          I grabbed this one
          Digital Kaos - Downloads - SSL84b for DM800 sim 2
          Then flashed a new SSL84b image which was this
          SIM2-SSL84b-TSimage-1.0.0-DM800HD-OE 1.6
          All working fine now! Ive not seen a single method online using what i did above.
          Note if you dont have XP and hyperminal. For Windows 7 you download putty under 'session - connection type - select serial and then you can select your com port there. I have not tested this with usb/serial lead. I read many things about driver issues with the maplin lead and was having so many issues with dreamup no responding i binned it using a direct com port.
          ******INFRACTION ISSUED******
          • mtv1
            The Stig PT
            • 4413
            Why link to another site it's all here and it's against the rules
            • marcelocwb
              • Apr 2013
              • 7
              Hi there, still no solution my problem, so if I buy a new sim card 210, it is possible resolve my problem?
              Cheers
              Marcello
              • marcelocwb
                • Apr 2013
                • 7
                Hi there, I tried with putty
                (c) 2007,2008 Dream Multimedia GmbH. All rights reserved.
                Dreambox DM800
                FIRST STAGE 1.0/400 {BO23456}
                2ND STAGE OK, build #84 (2011-09-01)
                0.000 - BCM board setup
                0.000 - fp init
                0.000 - ca init
                cannot read cert(2)
                cannot read cert(2)
                cannot read cert(2)
                cannot read cert(2)
                cannot read cert(2)
                CA invalid
                NO CONFIGURATION DATA PRESENT. STOP.
                lcd: * ERR01: NO CA FOUND
                0.865 oled: string too long: '* ERR01: NO CA FOUND'
                But nothing happens
                Cheers
                • ypvs125
                  • Dec 2010
                  • 506
                  Originally posted by marcelocwb
                  Hi my Dm 800 hd
                  sim 2.10
                  clone
                  error no ca found
                  tried optiflash ,NCF [ATTACH=CONFIG]242743[/ATTACH]but when ask to turn on DM, not happens, I use Null-Modem-Cable, I have checked port Com, is fine,
                  help please
                  Are u using usb adapter with yr null cable. That might be causing the problem.
                  • marcelocwb
                    • Apr 2013
                    • 7
                    Hi there,
                    yes using usb adapter, I will try with only null cable
                    Cheers
                    • marcelocwb
                      • Apr 2013
                      • 7
                      Cheers
                      • al strange
                        • Sep 2009
                        hi there i have had that problem quite a few times,there is a simple solution. What you need is a serial cable (female) to female and a usb serial cable adapter (male). install drivers with usb cable. look for the ncf repair tool run as administrator select com port 1 do job and your done
                        Last edited by al strange; 25 February, 2014, 14:11. Reason: other site advertising
