Evocamd 2.17c
This topic is closed.
The booster has dials/glides to trim the boost gain,put it on the worst channel and try adjusting the dials.
You may end up screwing other channels in your attempt to fix the worse channels.Checkout the RED stickies massive amount of info and effort been put into them.Comment
I did include a link,seems its been removed,shame......Checkout the RED stickies massive amount of info and effort been put into them.Comment
Cmon Shaz have you tweaked them dials yet???????Checkout the RED stickies massive amount of info and effort been put into them.Comment
D/load then transfer to var/bin/emu. After it as transferred then right click on it then scroll down to chmod then left click on it the change to 755 then press ok then reboot your box.Comment
looking for some help with my 500c.can anyone point me in the right direction to download some cams.i got evocamd 2.17,latest k3ys etc but channels still locked.maybe some different cams will work.Comment
. There is only 1 dial on my signal booster. I have turned it down, turned it up; but the channel freezing still happens.
