500c wireless connectivity
  • raulb
    • 9
    Hi Guys, twiddling my thumbs waiting for the dreambox to arrive I thought I would try to figure out how to connect it to the network. I did a little search here and there are not many threads on this and this could be useful to many folks.
    My current setup has the adsl modem and wifi router and PC in my room. The cable connection is in the living room downstairs. All laptops in the house connect to the internet via this wifi router in my room wirelessly.There is no way I can pull a cat5 all the way to the living room to the dreambox so I was figuring out how to make a wireless connection and get dreambox on the network and internet.
    1. I have a adsl plug point in the living room unused, I could use that but then I would have to move the adsl modem and router to the living room but since my main pc doesn't have wifi that would leave it without internet and necessitate buying a usb/pci wifi adaptor. Don't quite like this.
    2. Connect dreambox to a separate wifi router and bridge the 2 wifi routers. Since I already have a spare wifi router so that could work. Unfortunately you would think this bridge would be easy but no. It doesn't work that way. You can't bridge 2 wifi routers just like that. You need to by a separate wifi router called a 'client ethernet bridge' to connect something like dreambox and get it on the main network, incidentally I have a buffalo G54 HP and Buffalo G54S. That's sucks. Apparently something like Buffalo WLI TX4 G54HP would work out of the box to connect the dreambox to as a client, and get this they are usually more expensive than wifi routers.
    3. But no need to give up, you can load 'Tomato firmware' - third part firmware for some routers like Buffalo and Linksys - on one of the routers and apparently this will give you the option to convert it into a wireless/client ethernet bridge and connect the dreambox to it with the result that the dreambox will be on the home network and have access to internet. Cool. That's exactly what I need and even better unlike off the shelf 'client ethernet bridges' that usually have only one lan port, using tomato to convert a wifi router to wireless ethernet bridge has the advantage of giving you 4 physical lan ports in your living room that you can use to connect other things like game consoles like Xbox and HD-DVD players etc.
    Is anyone here using a setup like this?
  • caveman_nige
    • Feb 2008
    • 4920
    No mate, just bought a Belkin wireless bridge to connect to my existing wifi network, can put the bugger anywhere in the house, in my garage or next door if I feel like it. Same bit of kit also works on my xbox.
    Keep it simple dude.......
    • Devilfish
      Administrator
      • Feb 2008
      • 7872
      This is what I use in conjunction with my LInksys router.
      Experience fast, reliable, secure and easy to use WiFi when you level up with connectivity solutions made for home, business, and enterprise from Linksys.
      But I suppose any bridge would do.
      • kagon
        • 140
        So around 50 GBP for the bridges? Seems like it's worth it for the simplicity if you don't want the hobbyist project of loading unsupported images onto the extra router you have. Personally I've taken the "pull the damn cable" route, but as you've said... that's not really practical in your case.
        • raulb
          • 9
          I agree getting an off the shelf wireless ethernet bridge is probably a good idea to avoid more hackery, as if dreambox is not enough, but since I already have an extra router and loading and using tomato is easy, better to do that than go get another device.
          • hawkish
            • 27
            use a gamepoint! bridge - cheap as chips but make sure you get the version with the right type of encryption
            • smartbujji
              Instead of wireless bridge can i use a physical cable between dreambox and my laptop which has wireless internet connection in it and do some route forwarding so that inetrent comes in dreambox
              • caveman_nige
                • Feb 2008
                • 4920
                As devil fish says you will need to look into ICS (internet connection sharing) and probably install a small hub/switch in between the two, I would just go with getting a wireless bridge for the dreambox, sooooooo much easier.
                • funkeymonkey1973
                  • 17
                  Wifi....
                  When i moved in i had to have new central heating put in.
                  While all the floorboards were up to have the radiator pipes put in, I ran cat5 cable everywhere.
                  Now wherever i have a radiator i have faceplates with network points.
                  All the cables run back to the old airling cupboard with broadband cable run upto there to a wireless router and a 24 way switch box.
                  Had new extension on house last year - ran extra cabling to extension as kids rooms where being built on top level. put 3 wires through to each room for explansion. Also ran cables down the the old outside wall before it was plastered to run down for future conservatory.
                  Wireless is only on for laptop so i can use it in the garden.
                  Never Ride Faster Than Your Angel Can Fly.
