DreamBox 500c stuck w green light
  • RedRidingHood
    • Apr 2013
    • 29
    #16
    , detect port, but
    still stuck at
    Connection Prepared , please connect to DreamBox
    • advercar
      • Feb 2014
      #17
      Originally posted by RedRidingHood
      , detect port, but
      still stuck at
      I have a DM 500-S which has the same problem: The green light is permanently on when the unit is plugged in, using the standby button or the remote control has no effect, the light stays on. I've checked the ribbon cable connections and also used a known good working psu.
      Using Dreamup, with a null modem cable, it appears to identify the ip of the unit and displays: "Connection prepared, now switch on the dreambox!".
      At this point I've connected the power, but nothing happens. I've also tried it with the power connected before clicking on the Connect button, with the same result, so I can't flash.
      Any ideas?
      Thanks...
      • psats
        • 823
        #18
        Any ideas?
        Thanks...
        use an older version dreamup.
        • advercar
          • Feb 2014
          #19
          Thanks for the suggestion, but there's still no change. I've tried 1.3.3.9, 1.3.3.4 and 1.3.2.1.
          • toot69
            • Feb 2011
            • 15
            #20
            bro i think your flash chip is gone.
            • RedRidingHood
              • Apr 2013
              • 29
              #21
              yes, whole thing just can't work.
              in fact screwed up
              any more effort, i might as well get a new one.
              but no need.
              • RedRidingHood
                • Apr 2013
                • 29
                #22
                This box has given another user the same problem. Any remedy tried connecting w rs32 but no response
                • pekakbadak15
                  • Mar 2012
                  • 103
                  #23
                  It should be a null modem cable and not rs232.
