DM600PVR-c fix help
  • iuli78dizzy
    DM600PVR-c fix help
    Hello!
    I just got my first Dreambox, i installed the PLi jade3 image and now I'm stuck on how to use the emulator.
    I'd installed cccam2.1.1 and I would like to know what to do next.I found a softcam.key but I don't know if is this enough for my Romanian provider DigiTv cable and where to ftp it.
    Thank you very much!!!!
  • despdan
    • 544
    Dont know anything about Romanian cable but I would install mgcamd & evocamd then find the keys & rom files 9 search the forum & you will find them ). Put the key files into var/bin folder roms go in var/scce folder. Read the red stickies for howto.
    • Curious123
      • 2591
      Originally posted by iuli78dizzy
      Hello!
      CCcam 2.1.1 is used on the satellite boxes for cardsharing. I thought Digitv is only available on satellite and not cable.
      • iuli78dizzy
        Digitv is available also for digital cable and is using same k*ey and n*gra2 like the sattelite version.
        Thank you!!
        • Curious123
          • 2591
          Thank you!!
          If it is using the same keys as the satellite than I would search satankey bundle and install that on the pc. You could also check out the sat section as there have been digitv keys posted on the forum.
          • red devil
            • Oct 2008
            • 690
            maybe this is wat u need
            keys to var/keys
            scce to var/scce
            • Darren_Walsh
              • Aug 2009
              Its difficult to find a complete how to in setting up the DM600. I have downloaded and installed the pli image. Then in stalled the mgcamd and evocam from the downloads section.
              I am assuming this is a necessary next step.....
              Is there anything else I should know. I assume I have to set the permissions on this files to 755?
              • despdan
                • 544
                If you downloaded them from pli you won't have to set 755 you only have to do that if you manual install something.
                If you need more help ask we haven't installed mindreader.cam yet
                Where are you? service provider? system?
