Just a quick question guys as i am researching this atm
I understand about the building of the cable but im curious whether this would have worked?
I came across this img whilst i was surfing
RS232 DB9 to DB25 converter
Would this have worked instead of soldering the cable onto the board? if it did you could use the DB9 connecter in the dreambox.
Im assuming the cable legth resistance would be different so maybe not.
And just to help me can someone post the correct sequence of events?, every where i look there is different answers.
atm from several places the rough set i have is
check your printer port setup
u have to have bi directional i think?
make the cable with the 100 ohms resistors and solder it on the board
and use timing to power the box at the same tme you start jtag windows proggie?
but im aware there needs to be some sort of bootloader, where does this fit into the sequence
and the phillips / alps / cable tuners are they in the images or a seperate download?
plus how do we find out which one we have or need
i did some messing with telnet and the cat /proc/bus/dreambox command and i noticed phillips in the window ( nim = Phillips -C)
So im assuming mine is phillips the image i use is a dw 1.6.5 but im looking to change to a PLI soon
Im aware you can change the Mac manually with the init script or the telnet method but is that the best way?
Anyway just a few thoughts i had there will be more im sure
ps dont just say read the tuts , i have been for nearly 2 days now
