Missing certain channels even with a Signal Booster
  • th3sarg
    • Apr 2009
    • 20
    #16
    Originally posted by alexh
    If you systematically select each of these SID0x0x channels and then wait a bit, bring up the "All Services" list, the software will update the table, the list will update in front of you and (when you scroll back to the top) that particular "SID 0x0x" will be replaced with "(service removed)" and in the process extra channels may have been found. Repeat until all the "SID0x0x" channels are gone. This is a bug in the scanning software of Enigma based images.
    I believe this behaviour indicates that your friends are from the same provider (ex-NTL, ex-TW, ex-CW) and that is why the EPG part works, the channels are allocated the same MPEG2 PSI entries. However the "Signal not found!" message indicates they do not live in the same cable area as you. Their files have different frequencies for the transponders to those in your area. If you press menu->Information->Page3 and check the "lock" & "sync" you'll see they are not active (indicating there is no transponder on that frequency). Their files are useless to you.
    See if you can find someone closer to you. Or post the channels you are missing, what area you live in and perhaps some kind soul will post the transponder frequencies for you to perform a manual scan (with network scan not selected).
    Awesome post Alexh, thanks for that, I have alot of those SID 0x0x channels now so will test that out soon as I get home. My fiend only lives about 10 minutes from me, if that but I know hes on a different exchange and checked his internet connection (for the CPC zone thing) he's on "cpc1-bour5-2-0-xxxxx.cable.virginmedia.com" and I'm on "
    cpc2-char4-0-0-xxxxx.sotn.cable.ntl.com" Also selecting Bournemouth in the list of Areas to Scan on the Transponder Scan, it wont lock, but Southampton is fine.
    Anyway, I'm in the Bournemouth Area (Boscombe to be exact) so if anyone in the area does have some files they would like to share, I would much appriecate it!
    Thanks again for the help Alexh! Mucho Gracias!
    • Donnie Darko
      • 442
      #17
      Too strong a signal will cause channel loss or break-up,try fitting an attenuator to feed into box.
      Checkout the RED stickies massive amount of info and effort been put into them.
      • middlewingnut
        • 55
        #18
        Just catching up with the dreambox - I've been mucking around with the Wii for a while...
        Anyway, I'm in Poole - can I put up some files for you, or would that be on a different transponder thingamy?
        I think I get everything at the mo, certainly all the sports and movies, and Merdian etc (which took ages to find, bizarrely)
        Let me know which files you need, if it will help.
        • th3sarg
          • Apr 2009
          • 20
          #19
          Hey middlewingnut, yea that would be great if you wouldnt mind, I use DreamBoxEdit 3 to download all the services and backup my channels etc, not 100% which is the EXACT file with all the channels in, pretty sure it's "services" located in var/tuxbox/config/enigma (correct me if I'm wrong someone)
          Nice one
          • alexh
            • 225
            #20
            That list of areas is stored in the cables.xml file within the image. It is nothing clever, it is a collection of data scraped together from people posting their details on forums like this. There is always the possibility of a transcribe error or it going out of date.
            My friend only lives about 10 minutes from me, if that but I know he's on a different exchange and checked his internet connection
            Very strange. You are closer together than I would have thought for you to be on two separate cable networks with different transponder frequencies. Perhaps talk him into bringing his box to your house. If it doesn't work at all without re-scanning then you can be sure you are on separate networks. Whereas if it does... then you know it is your box and perhaps you need a variable attenuator or (less likely) a booster.
            Let us know how you get on eliminating the "SID 0x0x" channels. I recommend that before you start, you clear the "new found flags" next to each channel in the all services list so you can quickly see if you have found any more channels.
            Press OK->Red to bring up the All services list, navigate up and down, when you see one with an exclamation mark (!) next to it, highlight and press Info -> remove 'new found flag'.
            When you are finished you need to reboot your box from the main menu to save the state of these 'new found flags'
            • malangbaba
              • Dec 2011
              hi m8.i h just bought dm 500s with server but i have got the same problem.i get all the sky channels and some other but all the BBC and other asian channels r missing .i am on 28,2E direction.i tried auto scan ,edited frequency but still the same result.please help
