DUBLIN FIX??
  • amos
    • 19
    DM500 DUBLIN FIX??
    Some time since I've been here. Just wondering is there any new updates for Dublin area for 500c? thanks in advance.
  • Duggy08
    • 33
    Fix
    Hi Amos,
    Fix out for Dublin ages. Check the stickies and you will get all the info plus all the dowloads needed. I used dk v1.1 image. Works great
    Happy viewing. Hope this helps
    • amos
      • 19
      Duggy
      Did as you said and all smiles again!
      Again thanks to yourself and all at DK
      • amos
        • 19
        flashed with dk 1.1 and ftp'd files for ire fix. Did bruteforce scan, found c. 140 channels but pic has started breaking up and now no pic. Any help?
        • EAMO 2
          • 1201
          You could yry a re-scan using NTL cable ie
          or NTL mmds if using an aeriel
          I presume you changed HYP 1.06 attributes to 755
          • Tinnycan
            • 60
            Could be signal quality, do you have any splitters connected ?. If so use main supply coming in.
            Have full ver Ross-Tech Vag Com.
