AV Sender
  • manj63
    • 35
    DM500 AV Sender
    Hi, I trying to connect a second tv (in bedroom) to view and change channels using dreambox remote via an AV sender
    can someone advise what the best AV sender to buy/use that will enable me to view/change channels on second tv using existing remote control
  • Hejira
    • 35
    I've tried a few different wireless senders and found the AEI Digisenders not to bad for performance n function.
    h**p://www.argos.co.uk/static/Product/partNumber/5342608/Trail/searchtext%3EDIGISENDER.htm
    I would however add you just can't beat a cable for quality! With all the wireless equipment we now use around the home it's very hard to get a perfect picture wirelessly using a sender.
    • manj63
      • 35
      Thanks Hejira
      Will this able me to change channels using dreambox remote on second tv
      • dctyper
        • 2539
        i have one its a total control thingy, it allows you to change channel also, you put a sensor in front of your box
        • pawnhawk
          • 26
          Hi, I have the digisender X7, I know it costs alot more but it is brilliant. You can connect two boxes any stb and a dvd, and view them in another room, i've had it a while and no complaints.
          • Dreamer
            • 2020
            There is some info in this post too.
            not sure i in right forum but im on the look out for one of them digi senders wanted to know if anyone can recomend one and whats the signal like with them ta skints
            The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
            • manj63
              • 35
              Thanks every1
              Think i will look at digisender that doesnt run at 2.4ghzso to avoid interference
