HD Channels on a DM 500c
  • jfish
    • 799
    if I do a scan, will the new HD channels VM have announced be found, and I assume if I was to switch to the HD Channel on a 500c I will get them in SD format
    also if the channels be labelled as HD in another words how does one differenciate between the SD and HD channels
  • caveman_nige
    • Feb 2008
    • 4920
    no mate, you cannot view the channel(s) unless your box has a HD output.. Same case with the DM600C...
    • jfish
      • 799
      did a scan and in my area I got BBC, FX, MTV and Nat Geo HD
      can not watch them on TV but can view when using web-x-tv on my PC
      • caveman_nige
        • Feb 2008
        • 4920
        hmm can't say i have tried viewing them (HD channels)using that method yet... interesting to know..
        • jfish
          • 799
          problem is picture gets very pixelated
          the DM and my PC both connected to a 100mb router via wired connection
          obviously network bandwidth not enought to stream HD stuff to PC
          • dctyper
            • 2539
            leave it running for a while, it gets better
            • b595734
              I have a question; via web-x streaming 720p or 1080i content will be downscaled to 570i, for instance ? or content will be streamed "as is" ?
              • krazylegz
                • 2834
                content will be streamed as it is i think, however you cant view or stream HD on a DM500
                PS3= krazylegz120282
                • b595734
                  even though people say it can ?
                  • waqasahmed
                    • 433
                    You get BBC, FX, MTV and Nat Geo SD anyway so all you have to do for them is to search in your channel listings for them
                    Lose your memory sticks? Forget to backup? Why not get 2GB of free space online, and I get 250MB too
                    • krazylegz
                      • 2834
                      a HD box can stream HD but a 500 is only a SD so not possible as it cant decode the signal itself
                      • b595734
                        ok... reading this topic I thought that it could stream HD as jfish said he can view HD using web-x-tv on his PC
                        • jfish
                          • 799
                          does that mean when I stream from DM500c to my PC using web-x-tv - the HD content is not HD but SD ?
                          From my experiment, I can view HD channels on my PC but not on TV.
                          • dc_uk
                            • 12
                            What's this web-x-tv you speak of? I've been out the loop for a while
                            • alexh
                              • 225
                              Enigma based images have a built in webpage and one of the options is web-x-tv. It is not new, they have always had this feature as long as I can remember.
                              Basically it streams the filtered MPEG transport stream out of the box via the ethernet port and can be watched over the network on a remote computer using a web-browser if you have VLC media player and it's browser plugins installed.
                              However most images for DM500C are dodgy to say the least when it comes to this. A mixture of bad coding and RAM bandwidth limitations can introduce errors in the stream.
                              Also the latest version of VLC (1.0.0+) checks MPEG2 transport streams more thoroughly and rejects ones without PMT/PAT information. You end up with a black screen with "waiting for video". Someone in the dev scene should really get to the bottom of this and fix it once and for all.
