Collection of Plugins for Dreambox
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Tuxbox Commander
    Useful for editing files on your dreambox.
    Dream Netcast Internet Radio
    Listen to internet radio on your dreambox.
    Edit the /var/etc/stations.xml file to add new radio stations.
    Dream Weather X
    Weather information
    DB Switch
    If you have two dreambox receivers in the same room you can use this to assign a key to each receiver so that the same remote doesn't operator both receivers at the same time.
    Bit Rate Viewer
    View the bit rate of the channel you are watching.
    Installing on your Dreambox
    If your image has an Addons menu, copy the .tar.bz file to the /tmp folder on your box and install via the Manual Install option in your Addons menu.
    If it doesn't have this function, extract the files to your Desktop using WinRar and copy the files to the proper folder locations using your FTP client.
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Dreambox RSS Newsreader
    Great plugin for access newsreels from internet sites.
    Edit the \var\tuxbox\config\rss\feeds.xml file if you want to add new feeds.
    • pob639
      • Feb 2008
      • 224
      dreambox service xml files
      some services xml files
      • Richard_IOC
        Installation
        I am trying to install Tuxbox commander so I can access the password file on my box, does anybody know can I install itfrom a USB memory stick? The blue panel doesn't let me see any plugins btw, despite having definite internet connectivity...
        • Devilfish
          Administrator
          • Feb 2008
          • 7872
          What dreambox do you have?
          You can't add files via usb if you don't have tuxbox commander installed.
          You need to connect the box to your PC and use an ftp client to transfer files to the box. If you are going to do this, you can check the config file this way instead of using tuxbox commander.
          • Sean.Robinson
            • 16
            Hi, im a bit of a nemb to all this so sorry for the im supposing silly question, but what is the services.xml file used for and where do i place it on my DM500C?
            • Yusuffff
              • Oct 2008
              I want to use the tuxbox comander to get in my dreambox is that a good idea??
              • Devilfish
                Administrator
                • Feb 2008
                • 7872
                Why not use a normal FTP program. You will need an ftp program to install these plugins anyway so it would be easier.
                • alliv
                  • 299
                  sean m8 if i was you i,d change my username... you wont be so easy to trace. know what i mean?
                  is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.
                  • utdman
                    • 183
                    im going to try DB Switch
                    im going to give it a try as i have eagle sat receiver and db500c
                    • palli
                      • Mar 2009
                      Has anyone tested db switch yet?
                      • Devilfish
                        Administrator
                        • Feb 2008
                        • 7872
                        That plugin has been around for many, many years, nothing really to test, it works.
                        • qwyrp
                          Where must I put the plugin-files?
                          • piptaps
                            • 399
                            how do i add new radio station? I have the website
                            • dehowletts
                              • 35
                              loving the internet radio station functionality thanks!
                              i have a question though please if poss how do you add aditional stations please? (apologies if there's a sticky on this but i couldn't find one)
                              Cheers
