help
  • imanob
    • 188
    help
    ok you can tell by name how crap i am at this tried the noobies way of getting my dreambox to work still no luck can anyone tell me to find the rapid share link for me to download an any other simple way of doing this thanks
  • challah
    • 242
    what have you done sofar
    what image is on the box
    where are you
    • imanob
      • 188
      think i have managed to sort some things out got filezilla and a ftp trying to do this in work so not easy go try in morning and see wot happens then will ask again if /when i need more help
        flash the box with this
        RapidShare: 1-CLICK Web hosting - Easy Filehosting
        its one some guy gave me worked perfectly for my box in dublin theres no need to ftp the box after its all done in this file you just need dreamup to flash the box its very easy
        • amos
          • 19
          Daithi,
          I tried this image and it's working OK on nearly all channels. Was having problem on a few of the more important ones! Thanks for your help.
          • imanob
            • 188
            tried everything ftp wont connect to dreambox bought new leads stillno joy anyone no anyone in liverpool who could do it for me quickly mrs doin me head in
            • imanob
              • 188
              right here goes again got crossover cables router to laptop will this make any differnce wifi to laptop to dreambox got filezilla and flash thing put ip addy in and all other details keeps saying unable to connect t server any ideas why thanks
              • challah
                • 242
                if you are trying to install a flash image use dreamup
                if you are using filezilla to transfer files
                tick dhcp in the communication section
                reboot the box
                your computer will assign a new ip use that
                everything should be ok after that
                • imanob
                  • 188
                  tryd that still no ip address didnt change thanks tou
                  • junkiepilot
                    • 96
                    First download the image you want to use and then follow this easy guide:
                    IF YOU LIKE THIS POST PLEASE HIT THE THANKS BUTTON
                    • challah
                      • 242
                      did you have a ethernet/cat5 cable connected from your router to the box when you tried to change the ip
                      • imanob
                        • 188
                        thanks to all who have replied i have tryed almost everything downloaded all kinds of stuff to try to help me nothing has so far ive bought to ethernet cables and a null modem cable but everytime i try to connect to flash thing it wont connect plez help me
                        • Dreamer
                          • 2020
                          as challah asked in the post above. How did you try to connect the ethernet cable to the box? was it plugged into a router first or directly plugged from pc to box?
                          The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
                          • imanob
                            • 188
                            done both box to router pc to router still says not able to connect
                            • ManofScience
                              • 650
                              i have no problems using a cross over patch lead and a null modem. thats the best setup.
