### Digital Kaos v1 Dreambox Image for DM500 C/S/T ###
  • monksy786
    • Feb 2010
    #511
    the image works fine m8
    • alexthekid
      • Apr 2009
      • 46
      #512
      any one help me .. cant ftp to the box ... dm500 ... i can connect to dbox ... so cant understand how i cant on the dm500??
      • biggp
        #513
        how can i get the latest version of cccam to my dm500 clone box it has version 2 .10 on it would like to update this how to do it please any helpers image dk1.1 on it if this helps can i dowload direct via ethernet
        • cmcdermo73
          • 22
          #514
          i have installed this box and the magic keys.
          My problem is i have lost my remote, so i am controlling this via my pc.
          I need to access the EMU obviously i cannot hold down the info button for 3 seconds as i don't have the remote.
          Does anyone know how to get to the EMU so i can reset, thanks in advance
          • brooko
            • Mar 2010
            • 28
            #515
            hi
            i would like an idiots guide to flash dm500-c if you or anyone has it
            • ganesa81
              • Apr 2010
              • 13
              #516
              nagra3
              Originally posted by Devilfish
              Well it's been a long time coming but it's eventually here - Digital Kaos v1 image for all versions of DM500, cable satellite and terrestrial.
              Please read this post in full before asking any questions. All questions with answers in this post will be referred here.
              A few details about the image!
              Yellow - Kaos Panel (Extra settings, Manager suite, User features)
              Blue - Plugins (preloaded with a few)
              Red - EPG (double press to bring up a few options including EPG Search)
              Green - SubServices for satellite viewing, i.e. Premiere Sport Portal. Also if you hold it down for more than 3 secs it shows the DVR controls for recording.
              Info - Infobar popup as usual but hold down for more than 3 secs to bring up the EMU Manager, kind of a hidden menu.
              Kaos Panel
              Kaos Extra Settings
              --Loads of extra settings in here, have a look and have a play
              --Enable picons (/var/etc/picon)(attached) These are icons that show the channel logo, takes up room in /var so it's disabled by default, can also be downloaded from the addons menu.
              Manager Suite
              --Addons Manager - Download plugins, emu, configs, etc
              --Slot Manager - For smarcards (sat)
              --Infobar adjust - Adjust the position on the infobar on your screen
              --Backup Manager - Backup your settings, plugins, skins, config, services, bouquets, etc. File will be generated in /tmp called backup.tar.gz.
              --EPG Manager - Not used on the DM500.
              --Audio Language Manager - Set priority languages for satellite users.
              --Var Move Manager - Move /var to the /hdd, or /usb devices, not used on the DM500.
              Addon Manager
              --Install Local Addon - copy file to /tmp and install using this option
              --Server: DK Addons - Internet addons available to download
              --Uninstall Addons - Uninstall any addons you have installed
              User Features
              --Flash Image - Copy img file to /tmp and rename to backup.img
              --ServicesBackup - Creates a services.tar.gz file in /tmp with all services and bouquets
              --ServicesRestore - Restores services.tar.gz if placed in /tmp
              --ReloadChannels - Reloads channels if services or bouquets have been manually altered
              --BackupImage - Creates a backup.img file in /tmp - this is a complete backup
              --PanicButton - Removes emu, keys, roms, services, bouquets, etc...everything to make it a FTA image. A factory reset or reflash is required if you select this option
              Included Plugins
              DreamNetCast Internet Radio - Listen to internet radio if your dreambox is connected to the internet. Add stations in the /var/etc/stations.xml file.
              RSS NewsReader - Read RSS feeds on your dreambox. Including the Digital Kaos forums. Edit the /var/tuxbox/config/rss/feeds.xml file with your own feeds, although some have been added for you.
              Tuxbox Commander - For editing the filesystem on your dreambox.
              Teletext - Available via the 'TEXT' button on remote or via the blue button menu.
              Internet Image Updates
              All future image releases will be available to update over the internet.
              Menu > Setup > Expert Setup > Software Update > Internet Update
              If you are currently using a DW image and you want to copy your services and bouquets to this image, do the following...
              Using remote, Blue > User Features > ServicesBackup
              FTP to your dreambox and navigate to /tmp.
              Copy the services.tar.gz file to your PC.
              Flash the new DK v1 image.
              Copy the services.tar.gx file from your PC to your dreambox.
              Using remote, Yellow > User Features > ServicesRestore
              Exit out all menus, hold 'INFO' to bring up the EMU manager and press OK to start
              DO NOT COPY YOUR WHOLE /var/tuxbox/config/enigma FOLDER TO THIS IMAGE!!!! IT WILL NOT WORK!!!!
              No Keys or Roms
              This image is supplied without any keys or roms. It is a FTA image only!
              But I did find that someone has uploaded these files which appear to work fine with this and any other image.
              db_magic_files.rar
              Copy contents of Keys folder to /var/keys
              Copy contents of Scce folder to /var/scce
              Go to Sky Sports 1
              Hold INFO for more than 3 secs to bring up EMU manager, press OK.
              Wait.......
              Screenshots
              http://www.digital-kaos.co.uk/images/dk_info.png
              http://www.digital-kaos.co.uk/images/dk_panel.png
              http://www.digital-kaos.co.uk/images/dk_emu.png
              http://www.digital-kaos.co.uk/images/dk_addon.png
              http://www.digital-kaos.co.uk/images/dk_infobar.png
              Thank You
              Special thank you to all members of the Merlin Project Team, Nemesis Team and CLi Team. Also thanks to all beta testers, your input is very much appreciated.
              Digital Kaos - Downloads - Digital Kaos v1 Image for DM500 (cable and sat)
              Updated v1.1 Image here
              Fully information regarding picons can be found here...thanks Jasmeet_87
              Njoy!
              -Devilfish
              Hi Devilfish,
              it's 10 days I have tried to fix a dreambox problem. still no luck (:
              I flashed also a wrong image for SG but I live in glasgow.
              now I flashed back to image V1.1 20/6/2008
              but I cannot see any encrypted channels.
              in the forum I found out that glasgow has gone to nagra3 and nagra3 doesn't crack yet. so i need to wait or you have an advice? cheers
              • safid
                • Apr 2010
                #517
                hi i every body
                how is streming in dk 1.1 ?
                • kadnor
                  • 78
                  #518
                  what about DM 800 equivalent thread
                  Hi,
                  Do you have already on your site any Guide concerning
                  problems after scanning , no A/V but all channels are
                  installed.
                  TV screen shows that Ccam started.
                  Thank you in anticipation for your assistance,
                  Best Wishes,
                  regards, kadnor
                  Kaos Panel
                  Kaos Extra Settings
                  Manager Suite
                  Addon Manager
                  User Features
                  Included Plugins
                  No Keys or Roms
                  db_magic_files.rar
                  Go to Sky Sports 1
                  Wait.......
                  Screenshots
                  Thank You
                  Njoy!
                  -Devilfish
                  • cozyyy
                    • Apr 2010
                    Can you reupload the db_magic_files.rar, the link is dead.
                    Thanks.
                    • drews
                      • Apr 2010
                      • 5
                      #520
                      crased dm 500
                      i loaded new image then it crashed ?
                      • drews
                        • Apr 2010
                        • 5
                        #521
                        dm 500 now signal
                        my box has crashed iv got all channels but no signal need help to reload
                        • tomhick024
                          • 559
                          #522
                          Dont make much sense mate, how could you have all channels if you have no signal? People will need clearer information on your problem is before they will be able to help you! ie: what image? can you ftp to dreambox? what area you in?
                          Whatever!!
                          • jimbofazza
                            • Apr 2010
                            • 8
                            #523
                            any chance of getting these magic files sent over to me the links dead
                            • haley
                              thanks for you help you are star but i cant download it please help me
                              haley
                              • armyf9
                                • 16
                                #525
                                Hey
                                How does this compare to Pli Jade3? Stability wise?
