Please, please, please. Does anyone know how to change the keys in a DM500c.
how to change keys
If you are connecting directly to your PC you have to use a Crossover ethernet cable...the wiring is different to a standard ethernet cable. If you are trying to use a standard ethernet cable then you will need to connect your PC to a router and then run a cable from the router to your DM500. I think you can use any cables if your going through a router.
I just use an old BT Broadband router and two standard Ethernet cables.Last edited by hideous.ape; 7 August, 2009, 20:11.Comment
