How to get Chelsea Tv?
  • Kurupt
    • 6
    DM500 How to get Chelsea Tv?
    Since the new flash fix ive noticed chelsea tv isnt there, in on n*l in dublin does anybody know how i can get it back or is it gone for good from the boxes?
  • unadkat
    • 340
    I thought Chelsea TV is only available to sly users and not cable.
    then again I could be wrong.
    • Kurupt
      • 6
      It was on the box before the security upgrade, after the fix was released it doesnt show up on any of my automatic scans
      not sure if it has moved to only sly since, guess its possible
      • jonnboy
        • 57
        Hi m8, whats the freq for the channelm8.
        thanks Jon
        • Tinnycan
          • 60
          Chelsea TV still on cable. N*L dublin. Clearing on dbox2.
          Have full ver Ross-Tech Vag Com.
          • Kurupt
            • 6
            thanks Jon
            Thats what im trying to find out myself, anybody know?
            • EAMO 2
              • 1201
              If it's any help to you In Waterford Freq 339 & it's FTA(no encryption)
              • Kurupt
                • 6
                After more searches it eventually showed up, with a problem though
                its listed under a different channel name (shows chelsea tv listings for the whole day though) and its just a black screen on the channel
                Any way to fix?
                Thanks!
                • EAMO 2
                  • 1201
                  [QUOTE=Kurupt;254637]After more searches it eventually showed up, with a problem though
                  Which box you using ,are you cable or aeriel
                  • Kurupt
                    • 6
                    Dreambox 500c, using cable
                    • Sirus
                      • 340
                      I dont get Chelsea TV either.. have DM500c
                      I flashed my mates TheBox Super and he gets VH2 and other stuff I dont... how is that...
                      I never thought different boxes made a difference to what you get or dont get
                      • EAMO 2
                        • 1201
                        If you're using D.K.1.1 image, set location N*L cable.ie
                        Scan--BQT-update fast scan or try Brute Force
                        You could P.M. tinnycan for freq. & manual scan.
                        If you're using older image that could be a problem
                        • EAMO 2
                          • 1201
                          [QUOTE=Sirus;254967]I dont get Chelsea TV either.. have DM500c
                          If using DK1.1 or PLI-jade ,Set my Location should sort your problem.
                          Usually comes up "no chls found", but that's fine. When you go to
                          "Service Search" page correct Prov. I.D. will be displayed. Make sure
                          correct Sym.Rate, set to Fast Scan, Bouquet to Update, turn auto-scan off If you know 1st transponder value enter in freq. line & start scan.
                          In Ireland most areas will have 2 listings in "Set my location"
                          e.g. Waterford1 & Waterford2, but doesn't tell you which is cable or whichis MMDS.. You have to try No.1 then scan ,if you're missing chls. then tryNo.2 and re-scan. Always look in ALL SERVICES after a scan to see if any new chls. have been found.
                          Sometimes a weak signal will scan 12 T.P.'s but not pick up last T.P.
                          D-box will pick up any chl. that STVU3 picks up on scan.
                          If you are using older image on d-box you should really flash new image.
                          • Sirus
                            • 340
                            I can bearly make sense of that EAMO mate.... Im still a newbie at all these advanced scanning instructions stuff
                            I flashed a few images over the last year or so... have DK1.1 at the moment, I think my tuner may be going or something because it finishes scans with 1.30 mins left to go and stuff maybe missing out on a few transponders
                            No biggy anyhow.. at least I get the majority
                            • EAMO 2
                              • 1201
                              [QUOTE=Sirus;256447]I can bearly make sense of that EAMO mate.... Im still a newbie at all these advanced scanning instructions stuff
                              Sorry, Sirius, I assumed you were fully conversant with linux. I'm no
                              expert myself, I've been flashing cable-tuners for about 2 years. The last
                              6 months I've been doing linux & I'm OK loading images & FTP files, but
                              when Paul(plasterer) Satsmo, & afew others start going into nerve-centre
                              of linux boxes, I move on.
                              I would say you're doing everything right, once location is correct. I set up
                              4 d-boxes yesterday, 3 were fine, 1 would not scan. So I just backed-up
                              services xml. & bouquets xml. from working box to desktop. Then just
                              copied both files to var/tuxbox/config/zapit.
                              Using dream
                              Services xml --go to ;var/tuxbox/config/enigma
                              Bouquets xml ---var/tuxbox/config/enigma/cable
                              There is 1 rogue bouquet file that goes in with services files.
                              A mate has a loan of my Dream500 while I fix his d-box, so I can't
                              check name of this file. Having sorted your bouquets look in tuxbox
                              folders to check this
                              Using older images scan would miss some chls, but with DK1.1 &
                              correct location this problem has been eliminated.
                              I presume you have tried bruteforce UK scan. Keep at it & you will sort it out.
                              Good luck
