can anyone tell me the correct way to manually add a channel on my dm500c please
help manually adding channels
there is no correct way to manually add channels, you can do it via your remote control using tuxbox commander, or you can use an FTP programme, and edit your buquettes. Or you can manually scan for them. But in all cases you will need the codes to enter.
look here
there is other threads on this, maybe you have to do some reading, i had a quick look for them, but running out of timeLast edited by aftermath; 6 June, 2008, 19:07.
rescan and check in last scanned in the menu and if its there move it m8any information provided is for educational/experimental purposes only.Comment
not sure wot image u have but try ok and blue buttonany information provided is for educational/experimental purposes only.Comment
manual search
FX setting in my area: 219MHz if it does not lock try 219MHz and search.
these info are from Galaxie box 219MHz SID:1751 PCR:8190 VIP:512 APID:640 teletext:576
<--time2rest added 2 Minutes and 34 Seconds later...-->
if no lock try 218 MHzComment
