just got keymaster codes does anyone know where i input these codes please ?
keymaster codes
should be the same as the Itgate... you will need a FTP proggy like IPswitch...
after that once you have set it up and you have access via the FTP you will then need to look for the folder var / keys
you should then have a notepad file in there... if am right you then FTP that notepad file to the comp and then edit the keys on there
you will have like a few lines
for example: 5c01: 00: 1235665454545 and 01: 4564544556
edit the lines accordingly and send the file back to the box.... its hassle to update the keys like this everytime you better off just using the AU patch which is in the download section... if you cant find it then tell me and i will upload it on my FTP. I only have the AU patch for ex c/w
regards
unadkatComment
regards
unadkat
I have the au ones but theres channels missing like sky 1 and all the disney channels and nickoloadionComment
