hi,
It works fine, but now i got only signal through scart.
I've tried several images, but no change!
actual os:
* OoZooN-Image *
* Enigma2 experimental *
* 20140928 *
* OpenDreambox 2.0.0 dm800se *
* OoZooN.tv *
a shortcut from dmesg:
[ 876.177000] HDMI mode
[ 876.177000] use EDID to detect colorspace
[ 876.178000] using colorspace: 1
[ 876.257000] set fb to 2(0)
[ 876.258000] bcm_video_****og_port_setup (fmt=7)
[ 876.370000] SET FORMAT: display[1], format=7
[ 876.471000] set current avs auto aspect to 16:9
[ 876.471000] disable wss on display 0
[ 876.472000] set sb to 3(1)
[ 876.498000] set wss 7 on display 1
[ 876.500000] set current avs auto aspect to 16:9
[ 876.500000] disable wss on display 0
[ 876.501000] set wss 7 on display 1
[ 876.501000] set sb to 3(1)
[ 876.506000] set current avs auto aspect to 16:9
[ 876.507000] disable wss on display 0
[ 876.508000] set wss 7 on display 1
need advice
thank you in advance
deni
actual os:
* OoZooN-Image *
* 20140928 *
* OoZooN.tv *
need advice
deni
