help dm500c
  • eire
    • 12
    help dm500c
    hi, my problem is put the new fix in my new dm500c i did flash with dk 1.1, when i use flashxp to put the fix no connetion with the dmbox i use 5e patch cable, i did everything in the faq still the same problem any help please ciao salvo
  • ManofScience
    • 650
    you connecting straight from PC to dreambox? a normal patch lead won't work, you need a cross over patch lead.
    • Bonesy
      • 655
      if your dreambox worked first time, its very rare the network port would stop. So also possible settings in your software if messed up?
