Signal booster
  • ronaldo121
    • 97
    #16
    sorry mate for late response but i have had no luck i have tried booster and attenuator but no difference unfortunately!
    • Erazor786
      • 55
      #17
      A friend of mine had the same problem as u m8.
      Setanta Sports, and couple of the music channels just wouldn't come, carried on getting "Channel Not Available" the SNR on these channels ranged from 40k - 50k, not enough for a picture. tried all sorts of different things.
      told him to get the booster u have, and its kinda sorted his problems out. he plugged it in and turned the Gain i think all the way to the highest and now he gets the channels, the SNR is not at the highest, maybe at 60k abit above. but u only need 60k for the picture to clear and a decent picture as far as i no.
      Hope that helps m8.
      EDIT:
      One more thing, is the box connected directly to the feed, if not and ur a using a splitter, take it out connect it directly to the feed. also try and use a different coax cable as u could be getting signal loss through the cable, as i understand that if u bend the coax to much or the longer it is signal degradation is a possibility
      • Hobdell
        • 12
        #18
        What SNR are you getting with and without the booster?
        We can work out what you need if you give us the figures. You should be aiming for around 90% ideally.
        An attenuator will reduce the signal strength so having a booster and an attenuator will cancel each other out (if the same strength) bit can clear up some noise.
