forgot pin number for locked channels
  • jim1690
    • Oct 2008
    • 114
    DM500 forgot pin number for locked channels
    ive put a pin number in to lock some channels dut now ive 4got what my pin is any help
  • mini
    • 602
    Change the password on DM
    If you have forget the pass of your's DM , just make the next steps.
    1) Install and run TuxBox Commander plugin
    2) Change directory to edit /var/etc/passwd
    3) Remove the encrypted password.
    --> ATTENTION !!!! THE passdw file only !!! NOT the passdw-
    3.1) In the file /etc/passwd is the line:
    root:b:0:0:root:/root:/bin/sh or something as !!!
    root:dkjhfhlksfdiueyr736592cigsdjgfj:0:0:root:/roo t:/bin/sh
    3.2) the password field is the b or the encripted string dkjhfhlksfdiueyr736592cigsdjgfj
    3.3) Delete the b or the string .
    The line now is:
    root::0:0:root:/root:/bin/sh
    (for the DM500, if you are using an other DM keep the
    root as it is, you must delete ONLY the string)
    4) Save the file and exit
    5) Telnet to your DB with root user without password
    6) Create a new root password with the command : " passwd "
    If you want put the original file with user:root and pas.:dreambox in one directory in your's DM and if you forget again the pas. then just copy the file passw in the original location.
    Press thankyou if you find this post useful.
    • Balijagic
      • Aug 2009
      interesting...
