DM600 & dreamup
  • napster
    • 53
    DM600 & dreamup
    help
    has anyone got a tut for dreamup using network side of software, im hope this is faster option for flashing.
    cheers
    napster
    cheers
    napster
  • osborne82
    Dreambox Guru
    • 133
    Originally posted by napster
    help
    cheers
    napster
    you again heheheheh
    simple conect null cable up and ethernet but dont plug power on on dreambox yet
    tick use network box
    theres two boxes now for your ip addys one ip is for your PC and the other ip is for your dreambox
    you have your static ip addy so enter it there for the dreambox then hit conect
    power up your dreambox
    wait for it to initialise then hit the flash button nav to your .img file and flash
    it does two things now when connected via serial and ethernet
    for the flashing and erasing it uses serial but for the uploading of the image tis will use the ethernet MUCH MUCH faster
    hope this helps m8
    cheers
    osborne82
    ps telnet and webif is faster too
    • napster
      • 53
      thanks m8 but you dont find things out unless you ask one more thing is it a cross over cable or normal ?
      cheers
      napster
      • osborne82
        Dreambox Guru
        • 133
        np
        sounds like your getting stuck in there with ya dreambox damn fine box shame more peeps dont have a poke round and play more
        cheers
        osborne82
        edit: u edited your post while did this mine
        normal ethernet if going through router
        crossover if straight from pc-dream
        • kagon
          • 140
          Originally posted by osborne82
          np
          It's also a shame people don't use the Search feature and/or spend 5 minutes to look up half a dozen posts that address the same issue. Kinda defeats the purpose of having a "forum".
          • napster
            • 53
            i did you search first and there is nothing on here about it, so keep your oppions to your self
            cheers
            napster
            • aftermath
              • 4345
              Yes its nice when peeps use the search on forums, it does stop a lot of unnecessary questions, but Osborne and Napster are very experienced blokes and been around forums for many years, i am sure they would have used the search button many times before.
              • kagon
                • 140
                Google: "dreamup network dm600" hit up the first post, furthermore Dreamup over the network is probably not the easiest way to flash the DM600, see:
                Hello.. Im new to all this dreambox and cable malarky.. however it is fascinating stuff and would appreciate some advice/help getting a dreambox up and running.. really not sure where to begin so would be grateful if someone can point me in the right direction.. tia
                I've been playing about tonight and discovered this while looking through some files...don't know how useful it is to anyone lol but never the less.... If you have a DM500, DM56xx or DM7000.... eraseall /dev/mtd/1 && reboot If you have a DM600-PVR, DM500+ or DM7020... rm -R /etc/enigma && killall -9
                • JohnO1234
                  • 105
                  How come you don't do it through the web interface, is the box bricked?
                  Just my two penneth!!!
                  JohnO
                  • napster
                    • 53
                    http://www.digital-kaos.co.uk/forums...ead.php?t=3401
                    if you read the post i ask about the network side of dreamup !
                    cheers
                    napster
                    • kagon
                      • 140
                      I did read your post.
                      I'm replying in the context of "faster option for flashing" which is the web interface JohnO has mentioned and the process that those two forum posts outline. If you choose to ignore other ways of achieving exactly what you're asking that don't require a third party application and other screwing around that's up to you.
                      • Curious123
                        • 2591
                        When I first recieved my box I used dreamup because that what I came across until someone posted the telent method. I maybe mistaken but to flash with the telnet method you need to know the ip address of your box. napster is actually quite experienced with the Dm500 but he is still quite new with the Dm600 so i am not really surprised he is following the path that he is familiar with rather trying something completely new and bricking his box. I am sure like all of us once he try the telnet method he will not waste his time with dreamup.
                        • mjjr
                          • 39
                          you again heheheheh
                          I've a dm600 connectd to a network / router. I always get a checksum error when I try this method - so I do the following:-
                          1) conect null cable but dont plug power on on dreambox yet
                          2) start dreamup & make sure "use network" box is not ticked
                          3) power up your dreambox & wait for it to initialise
                          4) exit dreamup without flashing
                          5) enter dreambox IP addres into web browser
                          6) this brings up a bootloader page - there's a flashing option at the bottom
                          7) go into the the flash menu & nav to your .nfi file and flash
                          8) re-start dreambox
