Wireless connection to dreambox, access point or bridge?
  • ss0000
    • Mar 2009
    • 151
    I want to connect the dreambox wirelessly to the router and read a few threads here but just need some further assurance.
    I understand that to enable me to connect my router (upstairs) to the dreambox (downstairs) I need to hook up a wireless bridge to the dreambox.
    My question is will an access point be ok? I believe an access point is similar to a bridge but just need further assurance.
    Also if an access point will do, is this one ok to use.
    TL-WA501G
    anyone else use this model or similar?
    thanks in advance
  • Swiftie
    • 141
    Should be fine, but what router have you got?
    Personally I have done many bridge setups using DG834G's v3 and upwards. Not strictly for dreamboxes but for IT.
    E Pluribus Unum
    From the one to whom much has been entrusted, even more will be demanded!
    If you have received help from this post, press the "THANKS" button to show your appreciation.
    • Sicilian
      • 168
      This defo works Buffalo Technology - Products - WLI-TX4-G54HP : Wireless-G MIMO Performance* Ethernet Converter I know cos i've been using one for years. Also has a 4 port switch so you can hook up other stuff like ps3, xbox, another PC etc...
      Dont think an access point works, I think you'ed need to set it up as bridge if you used what your suggesting.
      D I S C L A I M E R My right to post information is protected under the rights for freedom act. In all instances, information discussed here on my posts are either hypothetical in nature, out of general curiosity, common knowledge, public knowledge, or role-play. Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader. I am not responsible for what you do with it.
      • caveman_nige
        • Feb 2008
        • 4920
        I use these myself and at ?15 a go you can't complain
        [ame=http://www.amazon.co.uk/Belkin-802-11g-Wireless-Gaming-Adapter/dp/B0002AGJOE/ref=sr_1_1?ie=UTF8&s=electronics&qid=1250853533&sr =8-1]Belkin 802.11g Wireless G Gaming Adapter: Amazon.co.uk: Electronics & Photo[/ame]
        • ss0000
          • Mar 2009
          • 151
          I have a tp-link router which in my opinion are sound routers, simple and straightforward to setup and work well so I thought maybe same manufacturer bridge would be good, could not find one so wanted to ask about an access point.
          Anyways thanks caveman_nige, the belkin one seems a proper bridge and its cheaper than the tp-link one so guess I'l go for the belkin!
          thanks everyone for now...till it comes to setting it up!!
          • Sicilian
            • 168
            Do you know if this supports WPA2 encryption?
            • skegsagypsy
              • Aug 2009
              • 1230
              Doesn't look like it m8 according to the specs:
              "Features wireless 64- and 128-bit WEP encryption"
              'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
              -Bishop Desmond Tutu
              • Sicilian
                • 168
                I didn't think it did. I need another, but i'll prob stick the buffalo model as I know this supports WPA2.
                • pande_monium
                  • Mar 2009
                  • 5
                  Hey Sic!
                  Just thinking aloud... won't the usb dongles (which come bundled with the routers these days) work for straight Wi-fi connection?
                  That's what they're for... but not sure how one would load the drivers for those darned boxes.
                  Has anybody tried doing that?
                  • westkill
                    • 2378
                    i use these powerline adaptors
                    powerline adapter, Computing, Consumer Electronics, Wholesale Job Lots items at low prices on eBay.co.uk
                    • Fano
                      • 331
                      TL-WA501G
                      thanks in advance
                      I have one of these myself running with a TP Link 541G router.
                      Great combination,very stable,works very well for me.
                      Highly recommended.
                      • caveman_nige
                        • Feb 2008
                        • 4920
                        sorry for the delayed response... Yes they do support wpa2, i run both mine on wpa2.. Out of the box and up and running in 10 mins.. easyyyyyy
                        • Sicilian
                          • 168
                          Damn belkin, why dont they put that on their specs!
                          I ended up buying another Buffalo model, could have saved myself 20 quid
                          • Sicilian
                            • 168
                            Originally posted by pande_monium
                            Hey Sic!
                            Not sure how if a usb wifi dongle would work with a dreambox m8. Tbh I haven't come across anyone saying they've got one working.
                            • ss0000
                              • Mar 2009
                              • 151
                              The question with a usb dongle is how would you set up drivers on the dreambox to get it working?
                              I managed to get the wireless gaming adaptor from amazon and use that.
