Is nrth an sth lanarkshire same as liverpool and mancs
  • marvo
    • 157
    DM500 Is nrth an sth lanarkshire same as liverpool and mancs
    with it being ex tw,,is it same ??
  • davemac82
    • 279
    it should work m8 try scanning with uk bruteforce when doing automatic scan
    • marvo
      • 157
      if i copy them on ,,can i undo just in case,,ty in anticipation
      <--marvo added 28 Minutes and 4 Seconds later...-->
      ive lost all programmes now can i go back?
      • davemac82
        • 279
        yeah just take them back out or reflash your box using dreamup with the original image that you are using
        • marvo
          • 157
          i think they are different areas
          • Devilfish
            Administrator
            • Feb 2008
            • 7872
            No they won't work. There are loads of ex-tw areas but they all have their own frequencies and transponder ids, so you can only use the services file for your region.
            If you're ex-tw, scan using the 6952 option, 6887 if you're ntl.
            • marvo
              • 157
              yes your right i can verify from going taround the houses last nite,, neh mind its all excercise ,,woof
              • Devilfish
                Administrator
                • Feb 2008
                • 7872
                If it all worked 1st time, where would the fun be?
                You'll appreciate it more once you know how to ~~~~ it up and fix it again
