DM800SE - HDMI
  • pratat
    • Aug 2011
    • 8
    DM800SE - HDMI
    Hi Gurus,
    Need some advise on this.
    The DM800SE is connected to the TV via HDMI, On the first boot , there are signal from the box to the TV.
    After the initial boot , the signal is lost. I have tried almost all the options in the box , change HDMI cables and nothing helps.
    With SCART , everything works fines.
    Any advise on what to do ?
  • laksapopiah
    • Jan 2015
    • 70
    Had you checked the A/V setting under Settings, System?
    Is the box configured with the correct connection setup? HDMI? DVI? DVI-PC? etc etc..
    • pratat
      • Aug 2011
      • 8
      I have set it to HDMI but it is not working as well
      From dmesg this is what i get
      [ 12.506000] HDMI: ignore false positive disconnect!
      [ 12.506000] HDMI: now powered down
      [ 12.506000] HDMI: Unable to retrieve Rx EDID info.. no rx device
      opkg list-installed|grep dvb
      dreambox-dvb-modules-dm800se - 3.2-21131001-r7.0
      Could it be a driver issue ? Any gurus with DM800SE using image 3.2 ?
      • ZM00601
        • Jun 2012
        • 39
        Reflash your image.
        • pratat
          • Aug 2011
          • 8
          Originally posted by ZM00601
          Reflash your image.
          I did and have re-flash a few times.
          Should I be using 1.6 or 2.0 ?
          • lolipop
            • 18
            Hi Gurus,
            could it be the refresh rate. have you tried 50 and 60mhz
            • pratat
              • Aug 2011
              • 8
              Tested all options , should be the HDMI gone..
              • laksapopiah
                • Jan 2015
                • 70
                I hope you had tried new HDMI cable, and new LCD TV.
                • pratat
                  • Aug 2011
                  • 8
                  Yes tried new HDMI cable , different TVs... still the same.
                  Funny thing is on the first boot via HDMI , i can see the screen. when the OS start to load , HDMI signal lost..
                  • jatrophaseed
                    • 589
                    When you boot, u see logo, after that, nothing....
                    Wrong image BL corresponding to sim BL version or wrong image.
                    • pratat
                      • Aug 2011
                      • 8
                      Hmm but it is working with SCART.
                      I tried both 2.0 n 1.6 , still not working =\
                      • jatrophaseed
                        • 589
                        Then it hardware problem, no 1 size fit all solution.
