retrieving ip from dreambox
  • oweny111
    • 36
    how do i get to know my ip from my drambox any1???
  • smirnoff_rules
    • 8603
    look in the menu and open the one that says network . ip at the top
    • marvo
      • 157
      do a IPCONFIG on your pc and see what your router is
      <--marvo added 3 Minutes and 4 Seconds later...-->
      or a "command prompt" and type "ipconfig" from all programmes
      <--marvo added 4 Minutes and 43 Seconds later...-->
      it should go then 1,2,3 for the address i.e, 192.168.1.1 192.168.1.2 192.168.1.3
      <--marvo added 0 Minutes and 39 Seconds later...-->
      these are only an example you willhave your own from ipconfig
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        Menu > Setup > Expert Setup > Communication Setup
        • smirnoff_rules
          • 8603
          thats if y have a image like dk or dw .. l was thinking u have the image that came with the box and havnt flashed it as yet
          • mjjr
            • 39
            If you use Norton Internet Security 2008, there's a network map button that will give you the IP of all attached network devices
            • smirnoff_rules
              • 8603
              l use network magic .. u can find in the normal places .. great if your boxes changes ip after a reboot u know straight away . also great if your want to share printers and pc's and your network manager isnt doing its job
              • Curious123
                • 2591
                Why not have a static ip addresses for your dreambox that way they never change.
                • marvo
                  • 157
                  I was going to take mine to show someone the difference between eurovox and dm500,,am i better keeping it on auto update??
                  <--marvo added 38 Minutes and 56 Seconds later...-->
                  That network magic !! its a big programme curious can you give me some tips,,Ive found the network plan with ip numbers,,what else can you do with it,,
